p0451 cel help
Old Jan 5, 2011 | 12:21 PM
ssturbo305's Avatar
p0451 cel help
I've been getting cel p0451 about once a month and been clearing it for the past three months. It says evaporative emission control system pressure sensor range performance. Please. Help I'm a noob when it comes to.cels and don't know what that means thanks
Old Jan 5, 2011 | 12:59 PM
RyRidesMotox's Avatar
EVAP solenoid needs to get fixed? Its the thingy that vents your gas tank or something like that... Someone else might know better than me.
Old Jan 5, 2011 | 01:19 PM
TorqueSSter's Avatar
Question I found this - help any ?
Linky to older Post
Britt
Old Jan 5, 2011 | 01:23 PM
umrdyldo's Avatar
I got 455 and 497 this past week. I actually heard the system make noise by the rear tank.
"Check Gas Cap" came up
I cleared the code and it never came back.
Old Jan 5, 2011 | 04:26 PM
Zander916's Avatar
https://www.cobaltss.net/forums/2-0l...py-lnf-207984/
This??
Pics included.
My purge valve solenoid went bad. You can disconnect it but I just replaced it. ~$40. Only one bolt, very very easy. It IS POSSIBLE that it can also give you a gas cap error. Mine did when it was disconnected.
Old Jan 6, 2011 | 10:29 AM
Stamina's Avatar
I think we're talking about three different things:
1) The Evap Purge Solenoid is the valve in the engine bay that controls how much fuel vapor the engine takes in while you're driving it around.
2) The Evap Vent Solenoid is a valve on the canister itself under the car in the back that allows the car's fuel tank to "breathe"/equilize when you're driving or filling up on gas.
3) There's also a Fuel Tank Pressure Sensor on the canister too, that monitors any changes in pressure.
I'm not familiar with the code itself, but according to the code's description it sounds to me like part #3 is circling the drain.
Old Jan 6, 2011 | 10:57 AM
umrdyldo's Avatar
I agree. OP, do you have any way to monitor fuel trims to see if you are having issues while driving. That might rule out #1
I am having problems with either 2 or 3. OP, are you having long starts or issues after filling up or anything?
Old Jan 6, 2011 | 05:31 PM
ssturbo305's Avatar
my car seems to run perfect. i have trifecta tune i can log and send to vince?
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
