Possible boost leak or bad turbo?
Old Aug 3, 2016 | 08:26 AM
aebooth6's Avatar
When I WOT the car sounds like it has a boost leak but it's not throwing any engine codes. It deffinately does not go ***** to the wall like it has in the past.
I did puncture a hole in the radiator fan body but I don't think that could be the problem.
How do I know if my turbo is going bad?
I know there's a lot of questions but I don't know what to look for and what could be the problem.
Old Aug 3, 2016 | 08:27 AM
aebooth6's Avatar
I also noticed this when I got under the car. It looks like it was cut. Any idea what this is?
Old Aug 3, 2016 | 08:35 AM
Looks like a bpv line going to the vacuum tank
Old Aug 3, 2016 | 08:49 AM
Yeah it looks like the nipple broke off. Definitely could be your issue.
Old Aug 3, 2016 | 10:46 AM
CudaJoe's Avatar
it looks like the vac line to the lower charge pipe. Mine broke off a while ago. have to replace lower charge pipe. If you look at your photo you can see the the stem in the line still. Your going to throw a code, it doesnt happen right away but it will happen. Took me a few days to a week of driving before I saw a code.
This photo was taken from underneathe the car looking up right? Take an above photo looking at the same vac line. You will see a pin hole next the to connector on top of the lower charge pipe I bet.. So basically you have a boost leak.
Old Aug 3, 2016 | 11:02 AM
Joe is right in thought it looked like the vac tank but it seems more likely to be the one going to the chargepipe
Old Aug 3, 2016 | 11:08 AM
user 72239's Avatar
Time to replace with ZZP lower CP. I had this exact issue on my Lower CP and it threw a code eventually.
Old Aug 3, 2016 | 01:36 PM
aebooth6's Avatar
Damn. I wonder how that happened. Will I need a new hose line as well?
Old Aug 3, 2016 | 01:43 PM
user 72239's Avatar
if you can get that plastic nipple out of the line, then no. but I got a new line just in case.
Old Aug 3, 2016 | 01:49 PM
aebooth6's Avatar
Is there s how to on changing the lower charge pipe? Is there a quick fix other then buying the lower charge pipe. How hard is it to change the lower pipe?
Old Aug 3, 2016 | 01:54 PM
user 72239's Avatar
its a pain in the ass.
I cut my zzp charge pipe in two and used a silicone coupler to make it easier.
Old Aug 3, 2016 | 02:08 PM
aebooth6's Avatar
Son of a b****. I am trying to sell my car tomorrow and want to get it fixed
Old Aug 3, 2016 | 02:18 PM
user 72239's Avatar
Try and find someone selling a stock lower CP. it still sucks to install but it should be cheaper.
Old Aug 3, 2016 | 02:23 PM
aebooth6's Avatar
That's a good idea... Do I need a whole new charge pipe because they plastic piece broke off in the hose?
Old Aug 3, 2016 | 02:30 PM
aebooth6's Avatar
Is this what I should be looking for?
Old Aug 3, 2016 | 02:52 PM
The zzp pipe was pretty simple to install for me, taking the stock pipe is easy but it's a pain to move around to take off. You shouldn't need a new line just take the plastic out if not I'm sure it has enough lag to cut that small portion and connect to new pipe
Old Aug 3, 2016 | 03:32 PM
aebooth6's Avatar
Okay I will see what I can do. Thanks for the input. And you guys are pretty sure that this is why I'm having boost issues?
Old Aug 3, 2016 | 03:37 PM
CudaJoe's Avatar
you could probably get the plastic stem out of the line by screwing a screw into the opening of the stem and yanking it out lol. If theres enough slack you could probably trim it. Try the screw part first. You may be able to tap the stock lower charge pipe you have with a new brass barbed stem as long as nothing else looks horribly cracked.
Probably best to replace tho.
Old Aug 3, 2016 | 03:38 PM
CudaJoe's Avatar
not a single doubt in my mind
Old Aug 3, 2016 | 05:07 PM
aebooth6's Avatar
I trust all you so I'm going to buy a new lower charge pipe. Thanks everyone
Old Aug 3, 2016 | 06:49 PM
aebooth6's Avatar
Does the vac line suck or blow air? Or does it only sensor the boost?
Old Aug 3, 2016 | 07:23 PM
CudaJoe's Avatar
I'm not quite sure. I'd guess it's gets pressurized when your in boost
Old Aug 8, 2016 | 11:23 AM
user 72239's Avatar
its designed to pull air from your lower charge pipe to help close the BPV. It goes from lower charge pipe, to the boost solenoid on the intake manifold to the bpv.
Old Aug 9, 2016 | 02:24 PM
ThePanduuh's Avatar
This happened to me. Drilled and tapped the LCP and got a hose barb mounted in it with RTV around the threads and the top. Thing PULLS now. No CEL for me and I was driving over a month. Couldn't figure out why it wouldn't boost after doing a few highway pulls and the bpv would open at 15 and drop to 10 and fluctuate between 10 & 15 at WOT. Fixing the LCP was easier for me than buying a new LCP because it's my daily. Took about an hour and a half to do and I needed to go to a plumber outlet for a 1/8" hose barb. I was able to remove the lower charge pipe plastic thing and took it with for size reference.
Jamie Craig
Apr 12, 2016 07:03 PM
Badbren_ss
Feb 19, 2016 05:57 PM
Badbren_ss
Feb 18, 2016 05:46 AM
Sl0wbaltSS
Feb 14, 2016 01:03 PM
turboecotec02
Feb 1, 2016 01:28 PM
