Problems with reverse
Old Jan 16, 2011 | 06:12 PM
dayhoff35's Avatar
my car has been grinding when i put it in reverse lately. I let the cat warm up cycle finish and let the oil temp get between 80-100 degrees, just incase that has anything to do with it. Also it only happens when i first initally put it into reverse, if i put it back into first then into reverse then it wont do it. Also its always after the car has sat overnight.
Old Jan 16, 2011 | 06:36 PM
TorqueSSter's Avatar
Exclamation Mine is intermittently stubborn to go in.
W/ the occasional grind.
Somebody here mentioned putting it in second first - no idea why it works, but it does.
Other than that, to heck w/ it - we have a 100K powertrain warranty.
As far as the cause - sluggish reverse synchros, maybe ?
Britt
Old Jan 16, 2011 | 06:41 PM
slowstang's Avatar
First then reverse always for me with no problems. Is the car parked on a hill?
JacBlackSS/TC's Avatar
Yeah when the car is cold its a pain to shift but the second gear trick works everytime but once I drive around a block or two everything is fine
Old Jan 16, 2011 | 06:50 PM
dayhoff35's Avatar
nope parked in a garage level and i leave it in first and then put it in neutral to warm up then go into reverse and this happens
Old Jan 16, 2011 | 07:18 PM
slowstang's Avatar
Before you put it in reverse put it in first and roll the car forward a few inches then go to reverse. Should fix your problem
Old Jan 16, 2011 | 07:20 PM
dayhoff35's Avatar
everytime? if i leave it in nuetral will that fix it also?
Old Jan 16, 2011 | 07:31 PM
TWM Performance's Avatar
When the car is parked, leave it in first. When you start the car, put it in neutral and let it warm a bit. Before shifting in reverse, always engage first before then get in reverse like some people already said. I always done that with all of my cars and never had an issue engaging reverse, same thing with my SS/TC!
Frank
Team TWM Performance
Old Jan 16, 2011 | 07:35 PM
dayhoff35's Avatar
ok thanks for the good info guys
Old Jan 16, 2011 | 07:44 PM
user 70823082's Avatar
This happened to me for the longest time I took it in got a brand new tranny under warranty!
Old Jan 16, 2011 | 08:31 PM
dayhoff35's Avatar
damn dont like to hear that lol but anyway for them to check that without yanking the tranny?
Old Jan 16, 2011 | 08:38 PM
SunburstSS's Avatar
If you actually hold the clutch down for 3-5 seconds then put it in reverse it wont grind !!!! 100 % gauranteed
Old Jan 16, 2011 | 08:49 PM
devilbmxer120's Avatar
It also has a lot to do with the fact that reverse is a straight gear, no synchros. My car used to grind too now i just put it in third then reverse and it works everytime.
Old Jan 16, 2011 | 09:53 PM
dayhoff35's Avatar
wanna put a friendly wager on it lol? jk man i usually hold it down even though i put it in neutral because im not usually awake when i first get in the car but ill try this and the reply below yours tomorrow and report back but like i said its only on the first start so ill try this and then the other the day after.
also its like 30 degrees here could that affect it? My clutch feels grggy the first time i drive the car too like where the clutch engages it feels rough, any relation? But if i turn the car off then back on its good.
Old Jan 16, 2011 | 10:09 PM
Maybe a little bit but mine did it in the summer too. As far as the clutch, I haven't ever had mine feel like that. The only time its ever felt rough to me is when I just start the car and go. But once its warm it goes away. :/
Old Jan 16, 2011 | 10:29 PM
dayhoff35's Avatar
yeah thats how mine is
Old Jan 17, 2011 | 02:55 AM
PrincessTurbo's Avatar
Yup I usually let it get a little warm and then engage into 1st-5th just to get any kinks worked out of the sloppy linkage. I know they have some after market stuff now. Something makes me feel like its the linkage but having no synchro is usually the culprit.
I learned the hard way- in the cold it makes it louder and its worse especially if its sat for a while for some reason in my experiences.
Old Jan 18, 2011 | 11:52 PM
MastaShaKe_88's Avatar
Hmmm I'm with you guy, I think its just a cobalt thing cuz I took mine to the dealer cuz it was buggin the **** outta me an I thought I broke somethin, an sometimes 1st was a bitch to get into..
They said it was my fault cuz I was either "racing" or "putting the car in reverse while it was moving forward" neither of which I did and after a long ass fuss and 2.5 months at the dealership, they gave me a new transmission, either cuz 'gm authorized it's or cuz they didn't know what they were doin... im leaning towards the latter...
*o an i was at less than 2.3k miles btw*
Even after the new tranny my car still doesn't go into reverse... I jus POP it into 4th an then put it in reverse, sometimes it gets embarrassing tho... sittin there waitin for my car to listen so i can back up lol...
That's a bad look tho Chevy
Old Jan 19, 2011 | 12:14 AM
2.5 months?!?!!?!? eff that!! I was going crazy not having my car for a week!!!
Old Jan 19, 2011 | 12:24 AM
Yea an I was in a ls hhr, I was literally dying inside :'( an I kept finding myself slamming the brake lmao
They wouldn't let me take my rental back and get my DRIVABLE car an take it to another dealership withou me shellin out for the rental. **** that noise, I called GM Thursday an had my car back with a new tranny Monday afternoon
Also they got nothing but bad marks on my review of their 'service'hehehehehe
Old Jan 19, 2011 | 12:54 AM
raynrishad's Avatar
I was having the same issues. Brought it in, dealership replaced the whole trans. Ran great, blew the clutch, took it in. Dealer said they wouldnt warrenty the clutch. They put it back together. Drove it home the ghetto way (matching the rpm of the engine and trans to get it into gear.) Got the new clutch ordered started pulling it apart... When the dealer took it out to check on the clutch and when they put it back together they never refilled the trans. they let me drive it home 8 miles with no fluid. Trans is ruined with only 2k miles on it -_-
Old Jan 19, 2011 | 12:58 AM
dayhoff35's Avatar
wow... but i decided not to take it in hasnt done it the past 2 days when i held the clutch in for a while
Old Jan 19, 2011 | 01:05 AM
K0ba1t 5s's Avatar
when this happened to me i brought it to the dealership, they claimed it was the clutch and gave me a new one. That didnt fix it. Later found out that its because the gears dont line up. The only way to do it is to put it in any gear then reverse. Or you can just put it in reverse super slowly. Im to impatient for that so 1st to reverse it is. At least i got a new clutch out of it
Old Jan 19, 2011 | 12:24 PM
08SSTCRD's Avatar
Being a straight cut or helical style reverse gear is irrelevent, what matters is whether or not the gear itself has a synchro assembly.
In the case of the F35, I haven't had one apart, but according to GM its a fully synchronized transmission including reverse.
So in theory the transmission should not need to be shifted into another gear before engaging reverse, it should just engage smoothly regardless. As many of us know thats not always the case, so in order to ensure smooth engagement you simply select 1st gear before selecting reverse. This stops the input shaft from spinning, making it very easy for reverse to be engaged.
Old Jan 19, 2011 | 01:00 PM
Well there ya go, learn sumthin new everyday. I was just going off what i read on here awhile ago.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
