Proper way to fill coolant?
Old Sep 1, 2011 | 12:58 PM
seeyaass's Avatar
Well I bought a gallon of dexcool 50/50 then ran out and topped it off with Nestle Pure Life water lmao driving around temp stays at 184* when I park it won't go over 194*...guess it cant be that bad right? Lol
Old Sep 1, 2011 | 01:35 PM
BYT*SS*TURBO's Avatar
Its not a temp thing, its a **** in the water contaminating and dirty'ing up your cooling system thing
Old Sep 1, 2011 | 02:05 PM
seeyaass's Avatar
Ahh **** I see!
Old Sep 1, 2011 | 02:23 PM
Gremlin85's Avatar
Originally Posted by seeyaass
Ahh **** I see!
Now you and the mad scientist have to rip apart the block and replace those piston rings you fried...
Oh wait, wrong thread.
You should be ok, but I would probably flush the whole system.... but thats just me. I can be excessive sometimes lol.
Old Sep 1, 2011 | 02:39 PM
I agree. I would prolly do the same to be safe.
Old Sep 1, 2011 | 03:40 PM
seeyaass's Avatar
Yep will do thanks for all the input guys.
So flush, refill with dexcool ONLY. Correct?
Old Sep 1, 2011 | 03:53 PM
50/50 mixed dexcool. If you have to mix it yourself, make sure you dont use tap water again lol
Old Sep 1, 2011 | 04:01 PM
bamaboy22's Avatar
The tap water has elements in it that will cause a build up over time and it's not good for the system if that helps explain more. It's almost like a build up in your shower from your water over time except in your engine
Old Sep 1, 2011 | 04:44 PM
seeyaass's Avatar
Yep, understand. Will flush and refill sometime next week!
Old Sep 1, 2011 | 05:12 PM
sponge14's Avatar
How much tap water was used anyways?
Old Sep 1, 2011 | 05:17 PM
  #36
zerosk8ter83's Avatar
well since this thread is about radiators what do you guys think about pouring radiator sealant into the radiator?
Old Sep 1, 2011 | 05:26 PM
  #37
seeyaass's Avatar
Half gallon if that?
Old Sep 1, 2011 | 06:53 PM
  #38
bamaboy22's Avatar
I will slap you
Old Sep 1, 2011 | 07:11 PM
  #39
AARON-SS-TC's Avatar
lol^^^
i guess i need to do a radiator flush.
my car stays around 199-205, but at the track last week it was at 220!!!
Old Sep 1, 2011 | 07:30 PM
  #40
seeyaass's Avatar
Ouch thsts not good
Old Sep 1, 2011 | 07:45 PM
  #41
mine stays around 192 normal but at wot it can go up to around 215
Old Sep 1, 2011 | 11:13 PM
  #42
seeyaass's Avatar
My car driving around even wot wont ever go past 194 lol.
Old Sep 2, 2011 | 09:33 AM
  #43
That's how mine is too now. It almost never goes over 190 unless sitting in traffic, and then never over 195-196. It will actually go into the 170's on decel lol. Ill bet GM used a mixture with more coolant then water..
Old Sep 2, 2011 | 12:33 PM
  #44
sponge14's Avatar
I would really reconsider draining and flushing your whole system over < 1/2gal of tap water....
Old Sep 2, 2011 | 01:00 PM
  #45
seeyaass's Avatar
Yeah same here nick. And Sponge, im gonna flush everything sometime next week
Old Sep 2, 2011 | 01:11 PM
  #46
when the system is a lil over a gallon, half a gallon of tap water is a big deal lol..
Old Sep 2, 2011 | 02:05 PM
  #47
sponge14's Avatar
Good point, I didn't know we were that low volume.
Old Sep 2, 2011 | 03:49 PM
  #48
seeyaass's Avatar
Well I used a full gallon of dexcool.. and topped it off with water, not too sure how much cause I didbt think it was a problem lol. Will flush soon!
Old Sep 2, 2011 | 10:42 PM
  #49
guitarenvy's Avatar
check it with a refractometer after its mixed with water
Old Sep 5, 2011 | 09:53 PM
  #50
kikal8's Avatar
Originally Posted by NickD
Spill free funnel? This looks like overkill and unnecessary. If you don't have a steady hand just buy a $1 funnel from WalMart.
if u wanna do it CORRECT like the way a mechanic will do it so that there are no air pockets in ur coolant u will have a funnel so that u can see the air pockets causing bubbles and once they stop u r done. but hey. since all of u guys no how to do it then go ahead. its not gonna cause any big problems but id rather do it perfectly then fine...
