Proper way to fill coolant?
Old Aug 26, 2011 | 12:30 AM
seeyaass's Avatar
Well some of you may know, i hit a porcupine which took out my intercooler and radiator about a month ago. I had ordered a radiator and installed that awhile ago, and now my ZZP Ic/CP/couplers/clamps are coming tomorrow.
So just wanted to double check about refilling the coolant, right now its basically bone dry, I did go pick up Dex-cool coolant...
Ive read that to properly fill the coolant i have to take the top hose off the radiatior and pour the coolant into the hose, then into the resovior, start the car, let it idle while pouring it into the resovior.
Should that be all? Thanks guys! So excited to drive my car tomorrow its been like a month!
Old Aug 26, 2011 | 12:32 AM
blake05SS's Avatar
pour in the coolant
Old Aug 26, 2011 | 12:58 AM
seeyaass's Avatar
Well ive read something stating that you have to pour coolant in the hose going to the radiator.. Just wanted to double check on that
Old Aug 26, 2011 | 07:35 PM
AndrewSS/TC's Avatar
I've always just put it in the over flow tank, what else would the cap be for? Always runs normal temps.
Old Aug 26, 2011 | 09:18 PM
kikal8's Avatar
ha omg. you get everything set the way it would be if ur gonna drive it. pop the hood, open the radiator cap. go buy a the radiator filler funnels the has the correct cap for our car (Amazon.com: Lisle 24610 Spill-Free Funnel: Automotive). then just pour coolant in until it stops going into the radiator. turn the car on. let it get warm and watch the bubbles of air comming out of ur system. u may have to add more coolant as the car gets warmer. once the bubbles have stopped, plug the funnel with the tool they give you with the funnel and pull the whole thing off the radiator. put the cap on and fill the resevoir to fill line. your now set. no air in the system and you have the right amount of coolant in ur car.
Old Aug 27, 2011 | 12:44 AM
seeyaass's Avatar
Hah, well i did it today, I poured it through the hose on the top until it was filled from there and then filled the overflow. and its good as new now
Old Aug 27, 2011 | 08:31 AM
steven2008ss's Avatar
there is another way
Say AHH
sorry im in a troll mood
a hurricanes a coming
Old Aug 27, 2011 | 09:04 AM
guitarenvy's Avatar
Thats what the coolant fill cap on the overflow tank is for
Old Aug 30, 2011 | 10:16 AM
BYT*SS*TURBO's Avatar
You are supposed to remove the upper rad hose and fill it thru there first, then re-attach. Then top it off thru the surge tank. You then start the car and high idle it at 2k-2500 RPM for a couple mins, shut off and then re-top off thru the surge tank. Repeat the high idle and top off if needed.
Ever since I damaged my rad and refilled the coolant with new 50/50 mixed coolant, my car runs cooler. Not sure if the dealer uses more coolant then water or something but it's 100x better IMO now!
Old Aug 30, 2011 | 11:16 AM
guitarenvy's Avatar
or just use the fill cap.
Old Aug 30, 2011 | 11:51 AM
over flow is there for a reason
Old Aug 30, 2011 | 12:54 PM
seeyaass's Avatar
Thanks everyone. And nick that's how I did mine!
Old Aug 30, 2011 | 12:55 PM
good, that's the RIGHT way..
Old Aug 30, 2011 | 01:17 PM
seeyaass's Avatar
Yep, I remember reading that somewheres on here just wanted to make sure!
Old Aug 30, 2011 | 01:58 PM
guitarenvy's Avatar
did you use deionized water?
If not, then you did it incorrectly.
Old Aug 30, 2011 | 02:48 PM
seeyaass's Avatar
No, I used dex-cool gm approved coolant lol.
Old Aug 30, 2011 | 04:05 PM
guitarenvy's Avatar
I use crushed ice/ dex cool 50/50 mix, runs hot.
Old Aug 31, 2011 | 08:13 AM
NickD's Avatar
^this
Old Aug 31, 2011 | 08:14 AM
NickD's Avatar
Spill free funnel? This looks like overkill and unnecessary. If you don't have a steady hand just buy a $1 funnel from WalMart.
Old Aug 31, 2011 | 08:46 AM
bamaboy22's Avatar
No it's not over kill the proper way after putting it in is to "bleed" or "burp" the system after the coolant is full. This funnel he is talking about attaches to the tank fill about 1/3 the way run the car allowing the fans to come on 3-4 time or until no more bubble. Did none of you do this?
Old Aug 31, 2011 | 09:17 AM
NickD's Avatar
It really depends on the engine. Some engines can bleed all the air out by just running with the cap open and varying the RPM. Other engines come with a bleeder bolt you can open on when the system is closed and under pressure. I was under the assumption that our engines are the prior method.
Old Aug 31, 2011 | 03:17 PM
seeyaass's Avatar
Well I used dex-cool and some regular water cause I ran out of coolant, and when driving it did not go over 194°…
Old Sep 1, 2011 | 09:19 AM
You shouldn't of used tap water, that's a no-no! They sell the Dex-Cool 50/50 mixed at the auto store
Old Sep 1, 2011 | 10:06 AM
NickD's Avatar
Or you can buy distilled water at the supermarket or WalMart for something like 70c a gallon.
Old Sep 1, 2011 | 10:15 AM
Which is what I usually do if they run out, the 50/50 just makes life easier lol
