Recalls & TSB's
Old Apr 1, 2010 | 12:38 PM
JPizzle's Avatar
Recalls & TSB's
What are all of the TSB's & Recalls for the SS/TC. Or just other items you find wrong (oil leaking out of engine on driver side), (rear brakes suck), etc.
I'm planning a trip to the dealership for these problems:
Engine Oil Leak on Driver Side of Engine
Evap. Low Purge Flow
The Steering Column Recall....
Rear Brakes
and I had a problem with my TMAP wires on my cold side IC (I threw 2 CEL's & would only boost 5psi). I wiggled some wires around after Terminator told me to, and now I boost 20-21 just like I should.
Any other oil leaks, or anything like that I should have them look at?
Thanks guys!
Old Apr 1, 2010 | 03:03 PM
Iam Broke's Avatar
Hot side ? radiator support bolt that rubs through the charge pipe because it's too long. I CRS if it's hot or cold side though. You may have addressed it already with your CP.
Old Apr 2, 2010 | 11:31 AM
Hamrhead's Avatar
I had the Charge Piping recall done on my '09. IIRC, it was just a clamp.
**Edit** Just read your sig and saw you have aftermarket piping.
Old Apr 2, 2010 | 11:53 AM
SSlobalt's Avatar
My radiator support bolt almost rubbed through my cold side rubber piping. It was replaced under warranty when they were fixing my cracked IC.
Old Apr 2, 2010 | 11:58 AM
ssturbo305's Avatar
Rear Brakes
Thanks guys!
i called dealer by the phone and gave him my vin for the 09 ss/tc i have and he said my car isnt in the power steering recall. maybe yours wont either?
Old Apr 2, 2010 | 02:48 PM
JPizzle's Avatar
Yep. That's correct. I just had my oil changed a few days ago and they ran my VIN and the only TSB that they needed to fix was the bolt that held down the Hot-Side Charge Pipe. The steering never popped up in their system. So that's good.
Old Apr 2, 2010 | 02:51 PM
1badBlueberrySC's Avatar
Those with the squeaky clutch pedal... it is the Clutch Master Cylinder...
satisfied
Oct 19, 2015 12:35 AM
southal cobalt
Sep 9, 2015 08:21 AM
Adam144
Sep 3, 2015 07:48 PM
