Repaired the PCV nipple on my intake hose
Because it snapped off twice after using a JB Weld-type product and super glue. I had better luck with electric tape. This time I used a 5/16" hose ID barbed fitting from McMaster-Carr. I had to chop off the 2 outer barbs for the PCV hose to slide on far enough to lock into place. I used a 1/2" bit to drill into the intake hose after cutting off the broken plastic nipple edge. I didn't drill so far that the small duct that projects on the inside was removed, so that part is still attached. It worked pretty well.
OrangeCoba
Sep 25, 2015 06:06 PM
