Slicks on SS/TC
Old Mar 7, 2010 | 10:20 AM
cobalt9123's Avatar
Slicks on SS/TC
It's a tire question, but it's more about the SS/TC in general. I'm trying to decide between putting drag radials or drag slicks on some Drag DR-34 17" track wheels.
Will the stock axles hold up off the line with drag slicks? What about when doing a NLS to 2nd gear with GMS1 installed? Will I have any other parts to worry about breaking while using slicks?
I don't want to break anything on the car and I guess the considerable factor is the fact that when I shift into 2nd it's essentially a powershift which could put a lot of stress on the axles...anyone have any clue?
Thanks,
Old Mar 7, 2010 | 02:44 PM
cmiller8006's Avatar
It will be fine. Just have to make sure the wheels clear the brembos, or do like some of did or are doing and put some ground down lsj brakes and put some 15's on there.
Old Mar 7, 2010 | 10:06 PM
slowstang's Avatar
Slicks have alot more give in the sidewall than a drag radial does. You will be better off with slicks because they tend to absorb some of the inital hit while the drag radial does not. Drag radials can and do work but you'll need to slip the clutch alittle.
Old Mar 8, 2010 | 03:04 AM
SSlobalt's Avatar
If you don't want to break anything, drag racing is probably the last thing you want to do. Auto-X instead.
Jan 12, 2016 12:01 AM
camaromanss1992
Oct 1, 2015 10:51 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
