Snail_ss build thread
#427
I'd loosen the cradle bolts to lower it a bit. or just put a jack under the back of the cradle, loosen the front cradle bolts, take the rear bolts out but not completely. just enough to get past the threads but yet still in the control arm bushing so you don't have to line those bastards back up. then lower the back end of the cradle slowly by releasing the pressure on the jack some. it should pull the back of the engine down some which might give you a better angle to get at your leak.
#430
That was only 20psi just wait until we get it past 24psi!!
#433
I thought u had all the roads in Texas?
#437
I'm lucky we have very straight flat roads everywhere here it's really easy to find a good spot. When I go to Kelowna that's a different story and I've had to do 4th gear logs there on pretty bumpy roads
#439
Yeah it's been raining since yesterday and right now we have local police,sheriff and state troopers all over the place it's crazy. Also where I live the city was build around the highway so I would have to travel at least 30 to 40 minutes to find a good spot to do some logs if I want everything to be isolated. I usually do logs on side roads and only if I'm alone. You can say yeah a lot of excuses but I'll rather be safe and do them when it's clear and I don't have cops all over the place starting Monday everything should go back to normal with police presence
#440
KMO43 (01-16-2017)
#441
Haha what can I say I like good working conditions. weather hasn't been the best lately I'm not planning on going fast with all seasons tires and wet floor. Kinda seems when it's nice and have time to work on the car I'm waiting on parts or something is going on. But needless to say all I need to do is get my logs going and the car will be ready for the pulls I usually do them 10 minutes away but that area was packed with cops, now that the cop presence weekend is done I can go do all the pulls I want.
#442
Thats awesome Flash!!
#445
There's a very easy solution to this issue Snail
#448
Finally had time to change the gasket that was leaking coolant. I got time to readjust the waste gate but it didn't change anything, car won't make past 20 psi. Next is to do a boost leak test and a exhaust leak (or restriction) I keep hearing a rattle seems to be coming from my dp but didn't hear anything or see anything when I had it off for the turbo build but let's see what I find
