speedometer problem...
just noticed today that my speedometer is like 1-2 seconds delayed from what speed i'm actually doing. my RPD is right...but the speedometer isn't. it works...and is accurate...just delayed as hell...help? ideas?
yeah its completely normal. happens to my car also. if you look up my name on youtube youll see a vid of me doing a 60 pull from third gear. (i did it from third cuz i couldnt get a shot of the rpd and speedo and shift quick from second to third while holding the camera) when i do a 2nd gear pull its even worse.
yeah man i was doing a second gear pull to look at like 30-50 time and i punched it and nothing happened for like 2 seconds....while i was stuck in my seat lol...mind you i just got the car like last week...never noticed it till now. dah well! rpd it is
There are several things on this car that have their readings "smoothed" and therefore lag a bit. RPM, speed, barometer, the fuel gauge, and Boost/AFR/KR on the RPD all come to mind.
To clarify, I'm talking the RPM and speedo on the gauge cluster. The laggy RPM is what's always blamed for people messing up NLSs, for instance. Once they begin shifting "sooner" (from the gauge's point of view) then the problem is usually solved.
