SS Bottom Subframe same as other Models??
Old Jan 23, 2015 | 12:20 AM
Geo_SS's Avatar
I got a noob question guys. I wanna replace the bottom subframe because it is slightly bent on one side but I want to know if I can pull it off any other cobalt such as a non SS.. I tried to research and only found people trying to take it off.. Help will be appreciated thanks guys!
Old Jan 23, 2015 | 10:40 AM
blueLNFftw's Avatar
No. It is not the same.
I know this because GM replaced the subframe with a brand new OEM one on my LSJ. It took 3 weeks to get it because it was special order and SS specific.
The LSJ and LNF share the same one though. So you need a 05-10 2.0 SS model subframe to swap in.
Good luck with that. You will probably have to buy one brand new ($600 IIRC) since more SS models in the JY are super wrecked lol
Old Jan 23, 2015 | 01:10 PM
09CobaltSS1's Avatar
Yup, blue nailed it. The only subframe that will fit in a SS is another '05-'10 SS sub.
Old Jan 23, 2015 | 03:21 PM
kzak104's Avatar
Do you know what's different about it?
Old Jan 23, 2015 | 07:05 PM
intel's Avatar
^ I am also curious.
I thought the subframes were physically the same and would bolt up no problem. The only difference being that the 05-06 base and SS subframes having a bolt and tab for the sway bar bushings while the 07+ SS subframes were two bolts.
Old Jan 23, 2015 | 08:32 PM
Geo_SS's Avatar
Thanks for the input guys.. and **** thats gonna be a mission trying to find one at a junkyard.. guess ill start looking around online..
Old Jan 24, 2015 | 02:51 AM
andrewcarr1993's Avatar
Thought that was the only difference as well. Hell they use the same rear transmission mount.
Old Jan 24, 2015 | 10:04 AM
I probably should have worded that differently. I should have said, the only frame that you WANT is another 05-10 SS sub. All the subframes will of course physically fit interchangeably, but the non-SS frame is substantially flimsier and prone to torque flexing. If I remember correctly, they're both different part numbers and are substantially different prices partly due to how much more robust the SS sub is.
Either way, you should always replace your SS sub with another SS of any year.
Old Jan 24, 2015 | 10:09 AM
YelCal7's Avatar
Has anybody ever thought about making alumium subframe ?
GaryGibblez
Jan 14, 2020 10:35 AM
Oct 21, 2015 11:57 PM
Cptnslo
Sep 24, 2015 09:32 AM
dieGone
Sep 23, 2015 10:20 AM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
