Stupid Question
Old Oct 14, 2011 | 08:09 PM
nutty21's Avatar
Originally Posted by Frogstofall
They look good. Use those and your trunk jack and you'll be fine. It may take you a bit longer to jack up but it works.
Kewl,
25 bucks and if I'm careful maybe I can return them.
Old Oct 14, 2011 | 09:17 PM
SSlobalt's Avatar
Originally Posted by nutty21
Kewl,
Personally, I wouldn't do this without jacking the car up, but I take out the fenderwells instead of removing the headlights. Either way, though, it's a lot easier to do if you can remove the front wheels.
Old Oct 14, 2011 | 09:54 PM
Wangspeed's Avatar
You're suicidal if you attempt this without a real jack and jackstands.
Old Oct 14, 2011 | 10:54 PM
Frogstofall's Avatar
You don't think it's possible to jack the car up one side at a time with the trunk jack and put jack stands under it? Or did I miss the point of your comment?
Old Oct 15, 2011 | 05:25 AM
nutty21's Avatar
One last check for tools required.
Anyone think of anything missed?
Old Oct 15, 2011 | 09:10 AM
Wangspeed's Avatar
Pull that stock jack out, and when you start jacking up, watch it twist and bend. Now think about sticking even an arm under the car. There's a reason why it's emergency use only. Plus you'll never get the height you need to work comfortably.
Old Oct 15, 2011 | 10:25 AM
Mark Aubele's Avatar
Seeing as replacing spark plugs was too much of a job to do yourself, would it be crazy to suggest you take it somewhere to have it done? Spark plugs are about 20x easier of a job than this is.
Old Oct 15, 2011 | 08:01 PM
nutty21's Avatar
I said I didn't have the tools...
I don't have that right sockets...
In retrospec they would have been cheaper to just buy them though...
Old Oct 15, 2011 | 08:02 PM
nutty21's Avatar
I got the height to work fine.
Old Oct 15, 2011 | 08:06 PM
nutty21's Avatar
Not sure why everyone takes the headlights out to take the bumper off. I didn't...
Old Oct 16, 2011 | 04:51 PM
  #36
Really dood? I used mine the day after I got my car. Worked perfectly. Maybe you got a crappy one. Don't you think changing a tire would take longer than sticking an arm under to place a jack stand?
Old Oct 16, 2011 | 06:22 PM
  #37
Wangspeed's Avatar
You don't (unless you're stupid) need to put any part of your body under the car to change a tire. The stock jacks are prone to collapse when over used, or not on a level surface.
Old Oct 16, 2011 | 07:40 PM
  #38
But your point was that it could collapse on you which could also happen on a tire change which takes considerably longer to do than the five secs it takes to place a jack stand.
I do agree that it shouldn't be used for every car lifting job though. I'll admit it has it's limitations and having a nice quality jack is by far preferred.
Old Oct 17, 2011 | 02:01 PM
  #39
CmplXty's Avatar
I'm with whoever said get the proper tools before attempting to do any kind of major work to your car, lol. If you have the right tools such as a good jack, etc, it makes the whole process 10x easier, plus less stressful if something screws up and you have to jack it back up to change something if something was put on incorrectly, etc.
Moral: Buy a decent jack! They aren't expensive, plus its not a huge problem if you really are moving in January to just toss it in your trunk.
Trust me from failed experiences, tools should always come before doing the work lol.
Old Oct 17, 2011 | 02:32 PM
  #40
nutty21's Avatar
Too late. All work done.
Everything's on and working fine now.
Old Oct 17, 2011 | 04:09 PM
  #41
Chevycobaltss3's Avatar
Now lmfao!!
Old Oct 17, 2011 | 10:32 PM
  #42
CmplXty's Avatar
Well congrats on doing it successfully without some tools lol
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
