Stupid Question
Pull that stock jack out, and when you start jacking up, watch it twist and bend. Now think about sticking even an arm under the car. There's a reason why it's emergency use only. Plus you'll never get the height you need to work comfortably.
Seeing as replacing spark plugs was too much of a job to do yourself, would it be crazy to suggest you take it somewhere to have it done? Spark plugs are about 20x easier of a job than this is.
I don't have that right sockets...
In retrospec they would have been cheaper to just buy them though...
I got the height to work fine.
You don't (unless you're stupid) need to put any part of your body under the car to change a tire. The stock jacks are prone to collapse when over used, or not on a level surface.
But your point was that it could collapse on you which could also happen on a tire change which takes considerably longer to do than the five secs it takes to place a jack stand.
I do agree that it shouldn't be used for every car lifting job though. I'll admit it has it's limitations and having a nice quality jack is by far preferred.
I'm with whoever said get the proper tools before attempting to do any kind of major work to your car, lol. If you have the right tools such as a good jack, etc, it makes the whole process 10x easier, plus less stressful if something screws up and you have to jack it back up to change something if something was put on incorrectly, etc.
Moral: Buy a decent jack! They aren't expensive, plus its not a huge problem if you really are moving in January to just toss it in your trunk.
Trust me from failed experiences, tools should always come before doing the work lol.
