Sudden Rough Cold Start
Old Jan 29, 2016 | 07:44 AM
dgascho's Avatar
Recently my car has been awful starting in the cold. (09 SS Sedan) It's fully bolted, s256et turbo kit, etc.
Things I am familiar with:
I know my cat warm-up is still enabled, and I'm familiar with how it starts with this.
I also know my tune is not perfect, and probably needs some adjustment, but I'm also used to how it starts with this.
However, it just recently got much worse, and not coinciding with the drop in temperature. It originally ran ok with the cold temps. It's been below freezing in the mornings here for quite a while, and one day decent (not good because of the previously mentioned problems, but bearable), one day awful. Remote start is almost useless, as it usually dies 2-3 times. Once it stays running, it sputters, bogs down, almost cuts out, surges, etc. for a short time. It lasts about the same length of time as my cat warm-up would be, I think, only much worse.
The rest of the time it runs perfectly. Even before the engine is warm, it switches to running fine after it gets through this issue. I can't think of anything I messed with or changed that correlates to when this started happening. Can anyone on here think of what could be causing this?
Old Jan 29, 2016 | 09:03 AM
Check your evap solenoid. You can start by just disconnecting it. Then I would be getting logging software and figuring out what's going on
Old Jan 30, 2016 | 11:03 AM
dgascho's Avatar
I appreciate the idea. Unplugging did nothing, but I stuck a new one on anyway, just to be sure. No change
Old Jan 30, 2016 | 01:15 PM
How old are the plugs and what plugs are you running? Given its not the evap it could be plugs starting to fowl, as they generally are bitches on cold start when they're going.
Old Jan 30, 2016 | 01:23 PM
dgascho's Avatar
Good point, I guess I shouldn't overlook the basics. I did check to verify it's misfiring across all cylinders, but I guess all the plugs are probably around the same level or age
Old Jan 30, 2016 | 01:49 PM
SR Tech's Avatar
Change the plugs for new delcos. Will probably take care of your issue
Old Jan 30, 2016 | 03:02 PM
cluelessk's Avatar
You letting the fuel pump prime before you start it? I've noticed cycling the pump twice on really cold days helps.
Old Jan 30, 2016 | 03:06 PM
dgascho's Avatar
I have been doing this and not noticing a difference compared to if I don't, but I will try doing it a couple times.
The strange thing is how when it was cold earlier in the year, I didn't have this issue, making me think something has changed or gone wrong. It's worth trying, as it may be a combination of issues
Old Jan 31, 2016 | 11:10 PM
dgascho's Avatar
New plugs made no difference. I'm starting to get convinced it's an electrical/tune issue, though I still can't figure out what changed or made it start doing this all of the sudden
Old Feb 1, 2016 | 02:54 AM
KMO43's Avatar
I just fixed another members idle here in the tune a week ago. You should get ur tune spot on first
Old Feb 1, 2016 | 11:53 AM
dgascho's Avatar
I appreciate your input, as your reputation with tuning precedes you. I shot you a PM/email if you have time to check it out.
Old Feb 1, 2016 | 04:59 PM
KMO43's Avatar
Thanks! I responded
Old Feb 19, 2016 | 11:22 PM
Psykostevo's Avatar
Your fuel trims are likely so jacked up that when they aren't yet operating your car can barely run, then after the car being on for a little time they start coming into play again and adjust to make the car run better.
I'm just taking an educated guess, but it's a pretty educated one.
Old Feb 21, 2016 | 03:12 PM
kzak104's Avatar
mine started rough starting right when i wanted to sell it, throwing no codes, got the tune dialed in which helped a lot, before the tune it would completely die, tune got it to stop dying but still started rough.
the day after i sold it it finally threw a code for the vvt solenoids on top of the valve cover, replaced it and now its perfect. took about a month for it to throw a code for anything....
stevehendo34
Mar 11, 2016 10:11 PM
06BlackCobaltSS/SC
Tuning
Feb 17, 2016 07:16 AM
Ben Blonde Rupprecht
Tuning
Jan 25, 2016 05:52 PM
droponikz
Jan 24, 2016 01:02 PM
