Take a look at these recalls...Could this be true?
http://www.alldatadiy.com/TSB/10/081...ml...Searching for recalls for SS/TC and I found this. You think this is for real or some scam...
http://www.alldatadiy.com/?gclid=CJ7...FQuJ1Qode0LkgQ
just put the year model and make in the boxes and you will see all the recalls and tsb's
Last edited by DennisMo3806; 08-17-2008 at 01:57 PM. Reason: Automerged Doublepost
this is the tsb i found on alldata Number Date Title
06-06-93-001D 05/01/2008 Fuel System - Clicking/Ticking Sound on Cold Start Up
06-08-67-019A 04/28/2008 Body - Headliner Wet Near Map Light/Sunroof Switch
02-06-03-009C 04/17/2008 Electrical - Battery Charging Tips/Recommendations
05-06-03-002C 04/17/2008 Battery/Charging System - Electrical Diagnostics Info.
00-06-01-012C 04/14/2008 Engine - Use of 'Surface Conditioning Disks'
boostedss...i just posted this on the same thread you are replying on...instead of spending time on this thread, you should try using Hooked On Phonics. Friggin Tart Cart.
im on way to many percocets..my bad guys
just had surgery.
had surgery
just had surgery.
had surgery
Last edited by DennisMo3806; 08-17-2008 at 03:44 PM. Reason: Automerged Doublepost
According to our fine government there are no recalls and 12 TSB's (for all 2008 Cobalts not just the SS).
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
