TC in the winter?
Old Jul 17, 2008 | 04:46 PM
  #51
silentd's Avatar
Originally Posted by thought
Yup, if you don't get Winter Tires, you are gonna be sorry - the SS tires are summer only. With the wide winter tires, I found it to be very capable (SC). (I don't buy this narrow tires to cut the snow crap - don't need grip on the ice under the snow - need grip on the snow)
you sir are an idiot..WIDER IS WORSE IN THE WINTER
your tires act as a plow genius.... your not going to get grip on the snow with wider tires... its going to be the same...
THIN and TALL for winter, its easier to get through the snow and you get just as much grip.
WIDE for the summer for more grip
Old Jul 17, 2008 | 04:48 PM
  #52
krispy's Avatar
Originally Posted by Bluebaltsc
Having a smaller sized tire or rim on the car is BADDDD for the LSD
Well I think most people would be getting rim/tire combo that is within a few % (under 3%) of overall stock dimension so their speedo is still right. Regardless, what the guy was refering to is when you put 2 overall different sized wheels on the same axle they will spin at different speeds and can burn out a clutch operated LSD if driven long enough.
My buddy has seen it happen w/ guys down in the ghetto putting on a spare on some RWD vehicle w/ a clutch LSD and it gets cooked since they drive a few thousand miles on the spare.
Old Jul 17, 2008 | 04:49 PM
  #53
Omega_5's Avatar
Originally Posted by an0malous
canada is actually in the process of making it LAW to have at least all-season or winters on during winter months.
I personally cant wait.
+1
I know it's the law here that tire shops have to sell winter tires in sets of 4, unless your looking to get a single replacement (ie; damaged). It makes me feel better knowing that many of the vehicles around me can not only drive and brake... but turn properly!
Old Jul 17, 2008 | 05:22 PM
  #54
yobrigidey's Avatar
This is only true if you use two different tire sizes (ie. the spare tire) If you put on shorter or taller tires than stock, as long as they are the same on both sides of the car, it won't make a bit of difference to the LSD. When you have different sized tires on the driver/passenger side, they make the axles spin at different speeds. The LSD sees this as wheel spin, and attempts to engage. Since the car is always doing this, the LSD is always trying to engage.
Old Jul 17, 2008 | 06:50 PM
  #55
1WhiteSSTC's Avatar
i traded the spare tire for an inflation kit/pump thing, no idea exactly how it looks/works but i'm sure it'll be better than a 16inch spare tire.....just extra weight in the trunk.
Old Jul 17, 2008 | 09:30 PM
  #56
MapOfTaziFoSho's Avatar
I don't think our diffs are clutch type, I am under the impression that our diffs are a helical or gear style...
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Macgyver2484
Sep 23, 2015 11:36 PM
tamadrummer
Wheels and Tires
Sep 11, 2015 02:47 PM
