tranny problems??
Old Aug 15, 2008 | 02:04 AM
ssturbd08's Avatar
tranny problems??
well i was messin around with some buddies and my tranns wasnt goin into gear i notice the other day, my stick shift felt different like it would move out slowly in gear but it never broke loose. now i got no 2nd like its not grabbin it at all unless i slam it into gear. so now i got no clue whats happen then for a while it didnt wanna go into no gear at all any suggestions on wtf happen???
Old Aug 15, 2008 | 12:11 PM
Nick_Z71's Avatar
maybe the syncro went for second gear?
Old Aug 15, 2008 | 04:07 PM
ssturbd08's Avatar
well see it does it in all my gears and when it goes in it dont scratch on anything. i'm hopin its just a linkage clip or something
Old Aug 16, 2008 | 10:33 AM
Terminator2's Avatar
If I am not mistaken because the car is front wheel drive the shifter is connected to the tranny by a cable maybe it is out of adjustment or something.
Old Aug 16, 2008 | 02:07 PM
IsItFast?'s Avatar
is the shifter "floppy"? Check the shifter cable bushings, there have been a few reports on the 08's of the bushings breaking. There is no adjustment on the shifter cables.
Then take it in - the car should be less than 6 months old, so I hope you are still under warranty .
Old Aug 16, 2008 | 02:13 PM
FiscalFizz's Avatar
I am a newb and not a wrench guy what-so-ever.. but isn't it ran with hydraulics and not cables????
Old Aug 17, 2008 | 05:05 AM
IsItFast?'s Avatar
The shifter connects via cables to the shift tower on the transmission. The clutch itself is a hydraulic master-slave setup, so no cables there.
Old Aug 17, 2008 | 05:14 AM
ls1fbody's Avatar
Haz l33t wheelz.
actually there is. there are two cables that the actual "stick" manipulates to move the forks in the tranny. there is a clip on each cable and they can be unclipped and moved to adjust the linkage. but it doesn't really sound like that's his problem
Old Aug 18, 2008 | 02:19 AM
Pauly204's Avatar
MY CAR DOES THE SAME THING AFTER TONIGHT!!!!!!!!!
out of nooowhere...my car doesnt engage in 2nd, 3rd, nor reverse...i justttt picked up the car on friday ..im pissed
Old Aug 18, 2008 | 07:12 PM
jerrodmann's Avatar
no problems here, yet... 740 miles...
Old Aug 19, 2008 | 04:53 PM
ssturbd08's Avatar
i just took it in. they told me something inside the tranny came loose i checked it out be4 i took it in and everything looked ok so i'm waitin to talk to the mechanic and see what happen.
mine happend at 2578miles
Old Aug 19, 2008 | 11:59 PM
rukkee's Avatar
The infamous roll pin issue is my guess, i'm surprised they haven't redesigned that yet.
Old Aug 20, 2008 | 12:01 AM
ssturbd08's Avatar
is that a known problem to cobalts???
Old Aug 20, 2008 | 10:42 AM
ssturbd08's Avatar
i just got a call from the dealer and they told me its the spring loaded pin that holds the shifter assembly in???
Old Aug 20, 2008 | 05:26 PM
ssturbd08's Avatar
i went to the shop to check it out and yes sir its the roll pin snapped right in between the 2 walls
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
