Trifecta
Old Mar 29, 2011 | 10:03 PM
NDCOBALTSS's Avatar
Trifecta
Do I need a new clutch if i get a trifecta tune at 22PSI? i have an 08 Cobalt SS with 33,000miles on it.
Old Mar 29, 2011 | 10:04 PM
BPacak's Avatar
Vtec Rep
no
Old Mar 29, 2011 | 11:29 PM
austinss's Avatar
You will eventually, no doubt about it.
Old Mar 29, 2011 | 11:36 PM
conerboner's Avatar
Are you gonna be getting the tune soon?
Old Mar 30, 2011 | 09:56 AM
tom.g's Avatar
So long as you don't do higher gear pulls at lower speeds the stock clutch should hold up to a Trifecta 22PSi tune. i.e. 4th or 5th gear WOT @ 50MPH = NO NO
Old Mar 30, 2011 | 09:58 AM
TheBoss8688's Avatar
I have the BYT tune at 24-25psi and I'm on stock clutch with Bo problems for now. Will need to replace eventually but not for a bit and I have been tuned for a year or so now
Old Mar 30, 2011 | 10:01 AM
Kyle4236's Avatar
Tuned mine 8k miles ago and clutch went last week. Waitin to put the new one in since its in my room but i never did high gear low rpms pulls. My girlfriend burned it up..... alot the 2 times she ever drove it
Old Mar 30, 2011 | 12:28 PM
08SStc's Avatar
my balt has 43000, nearly 20,000 on trifecta 22lbs tune, stock clutch and zero slippage
Old Mar 30, 2011 | 12:46 PM
tom.g's Avatar
RiceCop's Avatar
I've been tuned for over 20k miles, car has 21000 miles on it, stock clutch holding fine. Slips (on the tune, not in stock tune) if you get on it hard in 4th or 5th at a low rpm, which you shouldn't be doing to begin with.
Old Mar 31, 2011 | 08:20 AM
NDCOBALTSS's Avatar
Yes! Very soon I'd say by the end of April
Old Mar 31, 2011 | 08:25 AM
conerboner's Avatar
saweet i'll be tuning mine for 20 psi as well. also running e85 this year!
Old Mar 31, 2011 | 10:31 AM
raynrishad's Avatar
Roasted my clutch at 28k miles.
Old Mar 31, 2011 | 10:37 AM
JacBlackSS/TC's Avatar
i was fine with the stock one on trifecta but when i switched to the combo tune byt/tf i noticed a little slip in higher gears with the tune on but its small like 200-300 rpms if that much, but its fine stock, i am replacing mine so i can get retuned to make more power
Old Mar 31, 2011 | 10:45 AM
A8r9b's Avatar
Mines going bad around 24000, slips bad anytime t/c is off. Been tuned pretty close to day one. If you buy the tune directly from Vince@trifectatuning he will tell you the clutch is bound to go bad soonish. Might as well plan on buying a new one, not tomorrow, but sooner then needed.
None of us can tell you the condition of your clutch, but if its in poor condition from roasting, NLS's, launches, ect then you'll slip day one. If its in good condition you might go another 20k miles. Your prolly somewhere in between.
Old Mar 31, 2011 | 10:49 AM
bamaboy22's Avatar
I tuned at 1k miles. Now at 25k and holding strong
Old Mar 31, 2011 | 01:54 PM
Mark Aubele's Avatar
My stock clutch slips badly at 22k. Car is bone stock.
Old Mar 31, 2011 | 02:00 PM
CudaJoe's Avatar
I got tuned less than 1000 miles ago and my clutch slips pretty bad now.. no slippage before the tune even when flooring it in 5th gear. Now im back on the stock tune and Im slipping in 4th and 5th gear when flooring it at 3000rpms. Definately slippage after getting tuned. Looking at a new clutch so I can put the tune back on with confidence.
Old Mar 31, 2011 | 02:12 PM
Lytle_SS's Avatar
tuned for about 15,000 miles. I have 41k on the odo and the clutch will slip in 3rd, 4th, and 5th gear. I have to wait til I get to 4k before really getting on the gas.
BTW I have an 08 as well
Old Mar 31, 2011 | 02:22 PM
dthomp2366's Avatar
aww man and mine keeps asking to drive it and she's never driven a manual before either....i think I can talk her out if it for a little while longer...
Old Mar 31, 2011 | 03:37 PM
Kyle4236's Avatar
i was wasted out of my mind so i drunkenly handed my keys over and i guess in the long run i'd rather have a bad clutch than a totaled car. i smelled my clutch for a week both times she drove it... now i dont drive my car to the bar anymore besides the new KY clutch wasnt all that much
Old Mar 31, 2011 | 04:50 PM
ctn2mb's Avatar
My clutch went after around 50k miles of being tuned.
Old Mar 31, 2011 | 07:46 PM
dthomp2366's Avatar
yeah i'd much rather have my car than be looking for another balt. I spent a month looking for mine. SMH damned if I do and damned if I don't
Old Apr 1, 2011 | 02:53 PM
redninja6r's Avatar
I just rolled over 50k on my '09, been Trifecta Select-a-Tune at 24psi for 30k. No slippage.
Old Apr 1, 2011 | 03:40 PM
SSlobalt's Avatar
Did you get the factory flywheel surfaced? I'm curious how much that costs.
Doesn anyone have a pic of our flywheel? I want to see if it's grooved. Thanks.
chefhhr
Oct 26, 2015 10:36 PM
Canadia
Oct 6, 2015 10:20 PM
Adecker
Sep 28, 2015 10:57 AM
Dustin24
Sep 19, 2015 09:28 PM
09SSlow
Sep 17, 2015 12:50 PM
