True 0 to 60?
True 0 to 60?
I have noticed that most car manufacturers give a liberal number for the 0 to 60 times of their vehicles. For instance the SS/SC was rated at 0 to 60 in about 6.5 seconds and then you read about it doing 60 in 6 seconds flat. Will this theory hold true for the SS/TC? If so any estimates for the 0 to 60 times?
the lnf is not unerrated like the lsj was/is. i bet most lnf's will put out about 10-20whp more than a lsj, which is not enough to make too big of a difference. that being said, it will be close with a slight advantage going to the lnf.
how do you think the added torque will affect it? i believe its going to be rough geting this car to 60 in much under 6 seconds...hell my buddies GTI 1.8t starts hopping like a kangaroo once it hits like 2700 rpm and thats stock with like 173 tq.
power band is diffrent...maybe his car gets full trq at 3000rpm
Original Hayden Fanatic
GM says "around" 5.7 seconds for the LNF balt... You have to take into consideration, the SS/TC has the no-lift shift, which im sure really helps its 0-60 time
no doubt it's gonna b rough...cobalts r notorious for wheel hopping. but i don't doubt 6 seconds. it's do-able and also if u get some a/m tires and a torque dampner and get new mounts u've eliminated alot of wheel hop. i have a 2.2 and i put a stage 2+ clutch in and i hop ALOT when i launch. alot of it has to do with the driver. someone just going into a car isn't going to know alot about it, like launching, shift spots...etc. alot of it relies on the driver. i had to re-learn how to launch my car and how to just regularly drive it after installing the a/m clutch. also the electronic t/b didn't help either.
no lift helps on turbo's because they loose boost in-between shifts,where if u power shift a na/supercharged car,u wont loose any boost
yes i never even took that into consideration Super_SS...i guess that goes to show...me...gotta wait til its out...
cobalt_driver, i know where your coming from with teh wheel hop. i have a 2.2 eco fire now and it loved to hop before i got my motor mounts.
LNF was rated at 5.7 by GM, I've seen as low as 5.4 in a magazine (I believe it was Road and Track). It really depends on the driver more than anything. I find when Edmunds reviews a car, their 0-60 times usually suck compared to R&T.
I never know what my car does 0-60 because the speedometer is too damn slow lol.
its very hard to use NLS from 1st to 2nd simply because the gear is to short.... or at least if u use the NLS sometime the car wont let you put in second gear.... i did 0-60 when i was stock using COMP mode in 5.4 Sec.
As for 0-60 for the ss/sc GM rated it at 6.1sec to 60 straight outta the box. Some magazines did better or worse than GM's rating. The ss/tc was rated at 5.7sec to 60.
