tune-up?
Old Feb 26, 2008 | 01:48 PM
PaPiiShAmPuU's Avatar
tune-up?
About 3 monthes ago i installed a full exhaust system into my cobalt ss/sc and since then my gas mileage had suffered. I was told from alot of users here that i need a tune-up...i talked to the mechanic that installed erything for me n he said that it wasnt necessary n that my car's computer will adjust to the changes n if not i would have a check engine light...i havent had a check engine light yet (knock on wood) luckily...so should i really get that tune-up? n is it that necessary?
bump....any1 suggestions?
Last edited by PaPiiShAmPuU; Feb 26, 2008 at 01:48 PM. Reason: Automerged Doublepost
Old Feb 26, 2008 | 01:49 PM
Area47's Avatar
Rent me! per hour
you would get better results if you posted it in the right section
Old Feb 26, 2008 | 01:56 PM
which wud beeeee...where?...cuz it is a general question about the cobalt ss/sc
Old Feb 26, 2008 | 01:57 PM
Raven SS's Avatar
this is the LNF thread...u own a LSJ
Old Feb 26, 2008 | 01:59 PM
o0o0o didnt notice that f to j difference..mah badz
Old Feb 26, 2008 | 02:01 PM
Raven SS's Avatar
adding an exhaust system will lean u up..but if ur tune was rich than u wouldnt get a code..its good to have it atleast looked at by a tuner everything is going good and u might wanna get a wideband also
Old Feb 26, 2008 | 02:03 PM
o0o ok thnx...n can ask whats a wideband?
Old Feb 26, 2008 | 02:06 PM
Raven SS's Avatar
its a way to read ur air fuel ratio..u wanna be between 11.3-11.9:1
Old Feb 26, 2008 | 02:07 PM
n how would i measure that with the wideband?
Old Feb 26, 2008 | 02:10 PM
redlineblueline's Avatar
Wideband zirconia sensor
A variation on the zirconia sensor, called the 'wideband' sensor, was introduced by Robert Bosch in 1994 but is (as of 2006) used in only a few vehicles. It is based on a planar zirconia element, but also incorporates an electrochemical gas pump. An electronic circuit containing a feedback loop controls the gas pump current to keep the output of the electrochemical cell constant, so that the pump current directly indicates the oxygen content of the exhaust gas. This sensor eliminates the lean-rich cycling inherent in narrow-band sensors, allowing the control unit to adjust the fuel delivery and ignition timing of the engine much more rapidly. In the automotive industry this sensor is also called a UEGO (for Universal Exhaust Gas Oxygen) sensor. UEGO sensors are also commonly used in aftermarket dyno tuning and high-performance driver air-fuel display equipment. The wideband zirconia sensor is used in stratified fuel injection systems, and can now also be used in diesel engines to satisfy the forthcoming EURO and ULEV emission limits.
Old Feb 26, 2008 | 02:11 PM
Raven SS's Avatar
ky yankee has the explanation
Old Feb 26, 2008 | 02:12 PM
wikipedia had the explanation
Old Feb 26, 2008 | 02:13 PM
Raven SS's Avatar
i know i just wanted to give u credit for searching...
Old Feb 26, 2008 | 02:14 PM
yeah lol
Old Feb 26, 2008 | 02:20 PM
kk thnx...what would be a fair price for a tune up...
Old Feb 26, 2008 | 02:21 PM
Raven SS's Avatar
depends on u...they range from free to like 500
jczz24
Jul 28, 2019 04:31 PM
GfSwindle06
May 2, 2013 03:38 PM
elite1
Jun 13, 2012 03:56 PM
XgunsmokeX
Nov 8, 2008 07:26 PM
PaPiiShAmPuU
Feb 26, 2008 02:03 PM
