wastegate actuator rod
Old Dec 28, 2010 | 01:21 PM
ericgt79's Avatar
can someone post a pic and tell me exactly where it is so that i can check mine to see if its out of adjustment
Old Dec 28, 2010 | 02:56 PM
drewbroo's Avatar
its really easy to fine, just a pain to get too. Look where your Downpipe meets your turbo from the bottom. You will see the wastegate and actuator rod there.
Old Dec 28, 2010 | 02:57 PM
ericgt79's Avatar
so i need to lift my car
Old Dec 28, 2010 | 02:58 PM
drewbroo's Avatar
yes, unless you remove the turbo heat sheild.
Old Dec 28, 2010 | 03:14 PM
ericgt79's Avatar
whats easier?
Old Dec 28, 2010 | 04:06 PM
SXD45's Avatar
I use ramps for my car, pretty easy to get under and quick
Old Dec 28, 2010 | 04:15 PM
ericgt79's Avatar
yea my only gets on a jack if i drive up on 2x4's first
Old Feb 19, 2011 | 11:54 PM
ericgt79's Avatar
again anyone having problems with this?
Old Feb 20, 2011 | 06:59 AM
SSlobalt's Avatar
ONe of the members on here had an issue with it where the actuator rod actually came undone, resulting in boost during neutral revving.
Old Feb 20, 2011 | 08:14 AM
Iam Broke's Avatar
If the rod comes loose and the adjustment gets longer, you will lose boost. Term had this issue a while ago IIRC.
Old Feb 20, 2011 | 11:20 AM
army_greywolf's Avatar
he's not the only one to have that issue, happened to me, and the rod is a bit of a pain in the butt something tells me it was improperly installed to be loose at all, ever. It's a rare problem
Old Feb 20, 2011 | 03:12 PM
Iam Broke's Avatar
Yes, I know the locknuts on mine are Locktite'd from the factory.
Old Feb 20, 2011 | 06:39 PM
mine werent, but are now.
Old Feb 20, 2011 | 09:54 PM
ericgt79's Avatar
hmmmm ok im gonna check this tonight since my cars on blocks after i sold the wheels
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
Sep 27, 2015 08:53 PM
