What should my mods be?
Old Oct 23, 2013 | 01:30 PM
Trackguy's Avatar
I recently bought a 2008 Cobalt SS turbo and I am not as knowledgeable with GM as I am with imports. I already put on upper pipping and an exhaust. Bigger turbo? Engine Management system? Electronic boost control? What should I do? I had it on a dyno at 284 whp.
Old Oct 23, 2013 | 01:33 PM
nobody2u's Avatar
What are your goals with it?
Old Oct 23, 2013 | 01:40 PM
Trackguy's Avatar
Well I was doing drift events with my 1995 supra but I have done autocross several times. This is going to be my autocross car. I would also like to crush times and make hard pulls. Also I bought the car with a nice racing suspension. Not exactly sure what it is but it handles very well. My spending limit is 5,000. Thanks
Old Oct 23, 2013 | 01:48 PM
nobody2u's Avatar
If you are going to be doing autocross, you likely wouldn't need to go beyond the stock turbo in terms of power. A 3" downpipe, intake and a tune (you don't need a boost controller as boost is controlled by the ECU), you'll be within the 310whp~, 360wtq~ on the stock turbo (dyno depending). This will give you pretty decent pull on the highway, and you'll be spinning through second on street tires without throttle control.
In terms of suspension, Powell YYZ springs are likely the best for autocross. They may not be pretty (in that they don't drop the car very much) but they will likely get you the best times. A powell rear sway bar is another big plus for autocross (hardcore or XXX). Koni shocks are another upgrade, though expensive and not as much of an upgrade as the other parts mentioned above are. There are other minor suspension changes you can do via Powell parts that may help as well.
Old Oct 23, 2013 | 01:50 PM
Trackguy's Avatar
Okay thanks! What if i wanted to be running 390 to 425 hp?
Old Oct 23, 2013 | 01:52 PM
nobody2u's Avatar
Bigger turbo. ZZP ZFR, with 5th injector and tuned to run on E47. You'll definitely need a new clutch to run this and possibly a new transmission eventually.
Old Oct 23, 2013 | 01:54 PM
Tune, ZZP or Hahn intercooler, catless downpipe, hahn/injen/k&n intake. Find out what suspension you have, but for auto-x, Powell Race Shop YYZ spings, Powell CABs (leading and trailing), Powell XXX rear sway bar, Powell twisting beam bushings, Koni Yellow strut inserts, Koni Yellow shocks. And of course sticky tires (Nitto NT01, Dunlop Direzza Z2)
Old Oct 23, 2013 | 01:55 PM
574's Avatar
574
If you want to be serious about autox I would focus more on suspension as it was already said above, for autox a tune and dp would be just fine for power
Old Oct 23, 2013 | 01:56 PM
Way to much for fwd auto-x. These cars are torque monsters
Old Oct 23, 2013 | 02:43 PM
Shortbus's Avatar
The car must have a tune on it by the previous owner if you put down 284whp. If that's the case, I would concentrate on suspension from Powell.
Old Oct 23, 2013 | 02:50 PM
Could be GM Stg1, actually not sure what that puts down on the dyno tho. Also could be a happy dyno of a stock car
Old Oct 23, 2013 | 03:07 PM
Trackguy's Avatar
Thanks you, all this is very helpful and yes it has a tune that i bought it with. I have only had it for about three days so I am still discovering mods on it. I just looked in the car it has a Megan racing cat back 2.5 inch exhaust and a Megan racing suspension.
Old Oct 23, 2013 | 03:09 PM
slapbetcommissioner's Avatar
I put down 282whp with a 3"dp and k&n intake plus gms1
They put down around 270/290 with just gms1
Old Oct 23, 2013 | 07:25 PM
Shortbus's Avatar
Ditch the Megan suspension if you wanna auto X, you make decent power now to be competitive. Contact Powell race parts. Grab some Powell yyz springs and hardcore rear bar as stated before.
Old Oct 23, 2013 | 07:45 PM
m33pm33p's Avatar
A tune/dp/intake will not make you any faster or make your car faster at auto x. Unless you are a race proven pro, high hp fwd car is not a successful thing in auto x.
Like everyone has said before me, lay a base.
Good suspension and a good clutch in case in the future you want to up the power.
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
