where to get radiator and AC condenser ASAP
Old Aug 29, 2012 | 12:39 AM
tureka's Avatar
Hi all,
I broke my radiator and AC condenser with a jack like a dumba$$. Any ideas on where to get such items within 24 hours ? Links would be great. thanks
Old Aug 29, 2012 | 12:54 AM
abomb5501's Avatar
I use gmpartscenter.net for oem stuff. If they have it in stock it should ship same day and they offer expedited shipping plus till the end of the month you can get 10% off orders over $250 with code "lab10" You might want to call in to check with them if they have it in stock or not, otherwise your local dealer might be your best bet in a time crunch.
Old Aug 29, 2012 | 02:01 AM
Soofisahab's Avatar
car-part.com will give you nearby yards with the parts
Old Aug 29, 2012 | 06:32 AM
SSlobalt's Avatar
A/C parts should be the same as any Cobalt, so you should be able to get it at a yard. Car slipped off the jack, huh? Gestapo did that same thing.
Old Aug 29, 2012 | 09:06 AM
tureka's Avatar
you guys dont see any issues using an autozone radiator do you? need it today at latest tomorrow. car is actually at a friends house 20 miles away outside =(. i am hoping that the subframe supporting the radiator wasnt damaged. i want to get a radiator in it today, drive it home no ac. get a ac condenser and havr an ac shop drain the freeon
Old Aug 29, 2012 | 09:28 AM
cubaniche's Avatar
A/C should be the same...Radiator on an SS/TC is not. Make sure you get the one for the 2.0T cause there is the normal cobalt radiator that is same H and L but the depth is only 7/8ths as opposed to ours on the LNF wich is 1.05in deep. Thats a huge area missing if you accidentally get the one that is 7/8ths thick.
Old Aug 29, 2012 | 12:28 PM
tureka's Avatar
Ok, lucky I have interviewatruins for a friend. He helped me find a radiator + fan shroud + AC condenser combo from a tc
Anyone know how to remove the AC condenser and flush the fluid safely ? The current ac condesner is so wrangled i may not be able to get the new radiator in there.
Sean Cummings
Jan 8, 2020 10:17 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
xxenjoi11
Sep 29, 2015 12:36 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Cobe
Sep 19, 2015 11:04 AM
