Will GM put the 83% babysitter on the SS/TC
For a while I was interested in picking up a Solstice GXP so I cruised around the Solstice forums.
While I was there I read several threads about the throttle only opening to 83% maximum.
I wonder if GM will pull this same **** with the SS/TC also.
When I had a scanner on mine it said my TPS was only 97% when I had it to the floor. I know its only 3% but still. I figured on the floor was 100% but I guess not... It also said I had 13% torque reduction... I need some hptuners to fix these minor things...
LOL i dunno, i'm kinda tired
EDIT: Hatrickstu's car is the ****.
Good explanation, makes a lot of sense!
+rep-that-doesn't-exist-anymore to you.
+rep-that-doesn't-exist-anymore to you. Last edited by xravenwingsx; Oct 26, 2007 at 11:53 AM. Reason: Automerged Doublepost
even on the current ss wot throttle only reads as 85% or some crap... even though the throttle is completely open. It's just a #. It's not like it actually limits the throttle from opening more than 83%
::sigh::
all of the gm throttle by wire tb's up to 07, excluding the lnf vehicles only read 88% wot etc. the only reason why you see 100% via hpt is because the setting was changed to read 100%
me-1
cameron- 0
are you referring to the camaro?
Last edited by hatrickstu; Oct 26, 2007 at 01:14 PM. Reason: Automerged Doublepost
