1/8 Npt fitting thread amount
Old Jan 28, 2015 | 05:10 PM
tomj77's Avatar
So I'm doing a little project with meth injection and I'm wondering on a tapped 1/8 npt hole, how many threads should be contacting the fitting being screwed in? The hole is tapped in about 1/8 of material so it has about 4 threads after tapping. Fitting turns a few and gets right like it should. Is 4 threads enough u think or should I try to weld a bung on, this is cast aluminum so I don't know how well welding a bung will work
Old Jan 28, 2015 | 05:13 PM
If you can get a nut on the side through the pipe it will hold it much better. Sort of jam nut it into the pipe
Old Jan 28, 2015 | 05:15 PM
574's Avatar
574
Teflon tape
Old Jan 28, 2015 | 05:22 PM
tomj77's Avatar
I don't think a nut inside the manifold would be a good idea lol. And no Teflon tape, e6000 sealant. Meth proof
Old Jan 28, 2015 | 05:23 PM
tomj77's Avatar
All I need to know is if 4 threads is enough for a good hold, sealing it is no problem
Old Jan 28, 2015 | 05:45 PM
T-tape is meth proof also.
The nut on the inside is to hold the fitting into the mani. If your material is only 1/8" thick there is a good chance you'll blow it out
Old Jan 28, 2015 | 05:49 PM
tomj77's Avatar
I'd rather do a bung in that case. Be safer, I'd just be paranoid the but would fall off , plus if I ever wanna change nozzles if have to take off the manifold, that's just not practical
Old Jan 28, 2015 | 06:29 PM
Solaris99's Avatar
4 threads should be fine. See this https://www.pegasusautoracing.com/do...ocID=TECH00097
Old Jan 28, 2015 | 07:15 PM
tomj77's Avatar
Originally Posted by Solaris99
That's what I wanted . Then I should be good. Good stuff. Thanks
Old Jan 28, 2015 | 08:21 PM
blueLNFftw's Avatar
4 threads leaked on my lower charge pipe.
Old Jan 28, 2015 | 08:35 PM
Solaris99's Avatar
1.5 to 3 turns past hand tight? Torque is a big factor.
Old Jan 28, 2015 | 09:33 PM
tomj77's Avatar
Leaking threads is lack of proper sealant. Iv had more threads than that leak till I used a good sealant and a decent amount. E6000 has worked the best for me
Old Jan 28, 2015 | 10:01 PM
SSlobalt's Avatar
4 threads sounds fine to me
Old Jan 29, 2015 | 12:06 AM
tomj77's Avatar
I just checked the nozzle and they only have 6 threads, and ur not supposed to bottom a npt fitting out or it defeats the purpose. so 3 or 4 threads holding seems fine to me.
Old Jan 29, 2015 | 07:02 AM
Powell Race Parts's Avatar
The rule of thumb is 1/2 bolt diameter in thread engagement for maximum strength. The issue with NPT is it is an expanding thread and you have to be very careful threading it in too much. We made a meth fitting threaded into the runner in a stock LNF manifold for Cory ( R3volution) on here, I have some pictures someplace , it appears to be holding up but it is a fragile deal no doubt.
Old Jan 29, 2015 | 07:11 AM
tomj77's Avatar
So that would be just the right amount on the intake
Without using a bung. If it ever pops out I'll just simply weld in some bungs. I doubt it will though, I know my charge pipe nozzle is screwed in about 3 or 4 threads and that's held for a good while. And that e6000 sealant is like glue. So Ill be good. Fun project
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
