10 psi max
Old Apr 6, 2013 | 12:09 AM
Shortbus's Avatar
I swear my car is possessed!! If I drive it a certain way, very light on throttle the bpv sounds like its working, and it will boost fine!
Old Apr 7, 2013 | 03:03 PM
alerosaint's Avatar
Originally Posted by Shortbus
Where exactly is the solenoid located?
its on the turbo compressor, it has the electrical plug connected to it
Old Apr 7, 2013 | 08:30 PM
Shortbus's Avatar
Thanks ^
Old Apr 8, 2013 | 03:09 PM
Shortbus's Avatar
Everything has been checked, still can't figure this out!
Old Apr 8, 2013 | 03:20 PM
Sox-Fan's Avatar
Got Brakes?
Small boost leak?
Old Apr 8, 2013 | 03:37 PM
Shortbus's Avatar
Originally Posted by Sox-Fan
Small boost leak?
Completely ruled a boost leak out, the problem comes and goes. One day it will boost fine, then the next boost about 10psi, I can't hear the bpv when it does this. This car is practically brand new, I just don't get it!
Old Apr 8, 2013 | 03:50 PM
Terminator2's Avatar
BPV diaphram sticking open sometimes would explain the random nature and the lack of you hearing it blow off when this happens.
Old Apr 8, 2013 | 04:39 PM
Shortbus's Avatar
Thanks term! Will check again.
Old Apr 8, 2013 | 04:41 PM
Sox-Fan's Avatar
Got Brakes?
Is it a stock BPV or a Forge? I lost track.
Old Apr 8, 2013 | 04:59 PM
Shortbus's Avatar
Stock bpv.
Old Apr 8, 2013 | 09:13 PM
  #36
Shortbus's Avatar
This is getting very frustrating, i took apart the bpv, its completely clean no rips or anything, when i pressed the diaphragm the spring shot out. Can the springs go bad? Also its still doing it when the car gets to operating temperature. When i first started the car up it ran fine and everything operated as it should, right when it gets near 180 it stops working. WTF!!!
Old Apr 9, 2013 | 05:17 PM
  #37
Shortbus's Avatar
Thanks for everyone's help, this fixed it.
https://www.cobaltss.net/forums/2-0l...st-mod-191361/
Old Apr 10, 2013 | 02:16 AM
  #38
alerosaint's Avatar
good stuff..... I tried that and iirc i got tons of flutter, i guess ill try again
Old Apr 10, 2013 | 06:38 AM
  #39
dcrep06's Avatar
get rid of that junk BPV and buy the forge one, i had this same problem when i was stock, i had the GM tune and that was it, so normally i was supposed to hit 20psi, but during hot days towards the summer, it would either stick open or closed, sometimes only getting 5psi and then others it would spike to like 26 and hold at 25psi..........once i got the forge BPV it all went away, even during the summer.......and im using the heavy spring with the Forge BPV.
Old Apr 10, 2013 | 08:02 AM
  #40
Shortbus's Avatar
Many people on here have issues with the forge unit also, not sure i want to deal with that. Issue has been resolved with this https://www.cobaltss.net/forums/2-0l...st-mod-191361/
Old Apr 10, 2013 | 10:34 AM
  #41
dcrep06's Avatar
thats weird cuz i havent had a problem O.o but how did you fix it? didnt feel like reading all of that, i skimmed thru it, and it talked about cutting some of those lines? yeaaaa i wasnt going to do all that lol.
Old Apr 10, 2013 | 11:34 AM
  #42
Shortbus's Avatar
Basically you buy a 6" piece of vacume hose and bypass the vacume tank.
Old Apr 10, 2013 | 11:44 AM
  #43
dcrep06's Avatar
and that gave it more boost? idk if thats something i would do being that the tune obviously wasnt meant for more boost the way it was tuned lol. but if its just 1-2psi guess it doesnt matter much. good thing its fixed though.
Old Apr 10, 2013 | 12:47 PM
  #44
Shortbus's Avatar
I didn't do it to gain more boost, I did it to see if it would fix the issue of the bpv not working, and the car not boosting, and it fixed it. Vacuum tank must be leaking or check valve inside is bad.
Old Apr 10, 2013 | 01:43 PM
  #45
SSlobalt's Avatar
If bypassing the vac tank fixed it, then it's a leaky vac tank.
Old Apr 10, 2013 | 03:28 PM
  #46
dcrep06's Avatar
where is the tank? havent looked for it before. lol.
Old Apr 10, 2013 | 07:23 PM
  #47
Shortbus's Avatar
Yea I just said that lol.
The tank is located under the intake manifold. You can reach it from under the car and remove it with a 10mm socket.
Old Apr 10, 2013 | 07:45 PM
  #48
dcrep06's Avatar
oh ok, i prolly saw it when i took my IM off haha, just didnt pay any mind to it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
