'10 w/GMS1 Dyno 262 HP - Look right?
Old Jun 7, 2012 | 09:41 PM
axmonkey's Avatar
Got the Stage1 installed and put it on the dyno. This run was in 4th gear, not sure if 4th or 3rd was the best option. Anyways max HP was 261.8 does this seem like it's in the correct range?
https://imgur.com/xfyOo
Thx guys!
Old Jun 7, 2012 | 09:44 PM
09TcSedan's Avatar
looks right to me. for just GMS1 and not other bolt ons.
even tho bolt ons dont do a whole lot for GMS1
Old Jun 7, 2012 | 09:49 PM
chitala383's Avatar
Sounds about right to me, should do dyno pulls in 3 rd gear btw.
Old Jun 7, 2012 | 09:51 PM
09TcSedan's Avatar
i forget why they do a pull in 3rd gear usually. but yes in the cobalts ive saw dyno'd,they all have been in 3rd gear
Old Jun 7, 2012 | 10:33 PM
nhanson's Avatar
3rd is closest to 1:1 ratio.
Old Jun 8, 2012 | 02:58 AM
OntarioKev's Avatar
Looks to me like it is banging off a rev limiter at 6300 like the stock tune, shouldn't it go to 6500 on a stage 1?
Kevin
Old Jun 8, 2012 | 03:03 AM
DiabeticKripple's Avatar
GMS1 is supposed to be 280/320 crank so that looks pretty good to me
Old Jun 8, 2012 | 05:56 AM
Cobalt_Daddy's Avatar
268/291 here on GMS1 your numbers sound about right
Old Jun 8, 2012 | 07:07 AM
AARON-SS-TC's Avatar
wow, the power really drops off after 5500
Old Jun 8, 2012 | 11:50 AM
First pull drops off because ESC was still on and the car bugged out.
Old Jun 8, 2012 | 12:00 PM
nobody2u's Avatar
Looks pretty standard to me.
Old Jun 8, 2012 | 12:12 PM
user 72239's Avatar
My car dyno'd 269 whp with just an intake/upper charge pipe. that seems wrong to me but idk.
Old Jun 8, 2012 | 12:31 PM
dyno is just for baseline. some dyno's read higher or lower than others. stock the dyno showed 221whp and 219wtq
Old Jun 8, 2012 | 06:31 PM
axmonkey's Avatar
If it looks right but it's in 4th gear, wouldn't that cause it to read high? So if it's comparable to a 3rd gear pull, that would mean it's not really putting out what it should. I guess I should go get it done again in third so there's something decent to compare it to. I got the GMS1 in but I'm not really feelin it. So I'm trying to figure out if it's just me or if the car's having a problem.
Old Jun 8, 2012 | 06:34 PM
gear helps but doesn't matter that much... power is power.
both my pulls are in different gears and comparable. 3rd and 4th.
Old Jun 8, 2012 | 06:41 PM
Frogstofall's Avatar
I think 3rd gear pulls usually read higher.
Old Jun 8, 2012 | 06:42 PM
but is the OP really concerned if his dyno graph reads a few HP less because of the gear ratio? it's just a bseline to have an idea.
Old Jun 8, 2012 | 06:44 PM
I'm sure the difference is negligible.
Old Jun 8, 2012 | 09:54 PM
themacguy's Avatar
GMS1 is very noticeable over stock. Your numbers prove it.
Old Jun 10, 2012 | 05:31 PM
axmonkey's Avatar
Thanks for the info guys, I appreciate it!
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
