100psi in cyl #4!!!!
yeah, def. NOT the tune. but somehow, maybe just too much constant power for the stock engine to handle. I really dont think it was the meth unless it was a bad mixture, but i guess it is a possibility as well.
Sorry for your issues man. Hopefully you will be back and running strong soon.
I had a low compression issue last week turns out I needed a new head, prob crapped up valves it was covered under the powertrain. Before I dropped it off I talked to a friends friend whos a GM tech. He said the valve issue is very common and if it was a piston you would have issues with oil being in places it shouldn't.
how cold has it gotten where you are? I know my car with a stock turbo see's a pretty big leap when the airs in the 40's and 50's ...... cant imagine what an efr at 26psi pick up but I know the power increase puts alot more demands on the powertrain in my car. Any chance it might have effected yours?
I know the air changes alot and my fuel trims change to where the car starts adding fuel so just a opinion.
how many miles on the motor? how long are you staying at wide open throttle for on average?
a big part of what ive been seeing lately is people are staying at WOT for LONG periods of time....... to the point on the built motors they are melting heat tabs. the cars arent designed to do that built or not.
unfortunately it comes down to you pay to play. regardless of mechanical, tune, or whatever causes a break in a car its part of the game of going fast.
we had a car come in recenetly with no compression in number one....... pulled the motor apart. half of one of the valves was gone on the exhaust side along with the spark plug electrode. dont neccisarily think it was the tune that was in there BUT time will tell when i pull the logs. however it could of been something simple that a valve floated for literally a second too long or just a sheer mechanical failure. its the nature of the best and nothing lasts for ever.
I'm curious to see how many of you guys kill your motors with the efr swap. It comes down to the tune and driving style cause knock on wood I'm going on 2yrs of daily driving without any problems.
I can answer this, big gains! Can destroy the tires in 1st,2nd,3rd and 4th haha..
Haha.... i figured . If I can feel like I have 10-15 more whp you guys must get a ton. I start noticing my clutch starting to give up in third .... plus you can almost hear the car run crisper.... if that makes any sense
Yea, I literally feel like 40hp difference from 100* day to 60* nights with the EFR. One reason I do not run meth is for that reason that it can clog. If it clogs and you're at WOT, ahhhh :/
It does seem to have a different tone and just feels snappy.. My car is completely gutted right now so I can feel the difference with less weight also.
Everyone should have there tunes checked cause gas is switching over and you could see KR with the winter blend. I run the same 26psi but a little less timing and keep my fuel trim a little bit more on the negative side.
Yea I hear u guys and hey by no means am I pissed that this happened lol I kinda realy don't care to be honest just time to build the car now haha... but it has gotten pretty cold in ct been seein temps in the 40s now but like I saidi haven't realy gotten on the car that much which is y I was a little confused lol... but needless to say ither ill build it or ill build it haha... doint a leak down test later just waitin for my pops t finish doin wat he is doin
One question to you, what did you do to lose weight with the car. I'm going to 1/2 mile drag and the SS needs to lose weight. Anything you can recommend besides backseats/spare etc?
Should I be concerned with winter blend on e47? I'm in the middle of tuning so I'm guessing James will see KR if there is any.
turbo cars LOVES 60-45 degree weather, but the tires don't..
when it starts to get cooler outside, the ECM will start to adjust timing/ fuel/ coolant in order to complete the emission tests faster, due to the fact there is less oxygen content in the air when it gets colder outside.. within the next couple of weeks, everybody's car will start to get a little snappier once the outside temps hold past 50-41 degrees..
I'm really not sure where this is coming from, but I can assure you that the tune isn't nearly as aggressive as you somehow think. Boost is slowly ramped in to 26psi by 5500rpms so there are no boost/ load spikes at all. Timing is also obviously ramped in and peaks out at 17* up top, and tips in at 11* with no knock in all areas.
I wonder if the E85 is still different, though. I'll have to check.
