109 Octane?
Old Jun 29, 2009 | 03:11 AM
HB_SS/TC's Avatar
109 Octane?
Is it safe to run unleaded 109 octane in the lnf? I messed up the 3-4 nls at the track and the motor over revved to 8K then shut down completely. It'll crank but won't start at all. If I remember I got the p0300 301 302 304 codes
Until we get it towed to the dealership on the 6th my dad so far thinks I used too high of an octane and could have messed up the injectors or something that relates to the fueling.
Old Jun 29, 2009 | 03:25 AM
mkriebs's Avatar
So, you were using 109 octane at the time it happened? All of those codes are misfire codes. P0300 is a general misfire, and 301,302,303,304 are cylinder specific for cylinder 1,2,3,&4. Good luck getting the dealer to touch anything, I don't forsee it happening.
I am going to guess you messed something up in the valvetrain, much like Marin did when he shattered a lifter.
Old Jun 29, 2009 | 03:49 AM
HunterKiller89's Avatar
when you say messed up the 3-4 shift, do you happen to mean you made a 3-2 shift by accident? and unless you're tuned for 109, it only hinders performance. Are you sure it was unleaded? most fuels over 100 octane are leaded race gas
Old Jun 29, 2009 | 03:50 AM
mkriebs's Avatar
Good point... I didnt think of that, haha. For some reason, I forgot about the rev limiter.
Old Jun 29, 2009 | 07:41 AM
steddy2112's Avatar
The only way to get the car to spin that high is if you went 3-2
You can **** there all day and bounce it off the rev limiter and it will not rev higher than the limiter.
Period.
You fucked something up serious. Good luck trying to get the dealership to sponsor your race dream
Old Jun 29, 2009 | 08:31 AM
Terminator2's Avatar
That is not good at all. Misfires codes galore and wont start now. 8K RPMs did you miss 4th and get 2nd at 102 mph?
Old Jun 29, 2009 | 08:42 AM
06G85's Avatar
Just take the numbers off your car before you bring it to the dealership.
Old Jun 29, 2009 | 10:25 AM
HB_SS/TC's Avatar
Well it's a good thing that he works for the dealership.
And I know for a fact that I did not go into 2nd from 3rd gear
I'll give an update next week
Old Jun 29, 2009 | 11:42 AM
reign1's Avatar
he went into nuetral from what i believe and bounced the rev limiter really hard.
from what i remember.
Good luck bro.i hope ur car comes out better on top
Old Jun 29, 2009 | 11:43 AM
red2001ss's Avatar
Actually it will spin past the limiter if you do something like the 3-2 shift. THe computer will still be cutting the spark and fuel and all for the rev limit, but unless the wheels are practically locking in the front, the rotation of the wheels through the tranny in 2nd gear at 100+ will spin the components in the motor higher than what the rev limiter is set at. Basic Physics.
And yes you can sit at a stop or clutch in and bounce the rev and it won't go any higher and shouldn't damage anything, unless you're spraying Nitrous. Even spinning the motor way to high past 8k could cause spark knock and cause misfire even with the 109, at least my Buick would if I let it go too high.
Old Jun 29, 2009 | 11:47 AM
Maxim_X's Avatar
The fuel shouldn't matter of skrew anything at all up if it was unleaded. It's an unrelated issue.
Old Jun 29, 2009 | 02:32 PM
Zander916's Avatar
Yeah I'm thinking something broke or was damaged. There's lots of possibilities. Hell IDK maybe even the timing chain jumped.
Either way... I'm thinking the dealer is going to call it abuse (track use or street use, either way) and it won't be covered. But it's worth a shot.
Old Jun 29, 2009 | 04:36 PM
rukkee's Avatar
After looking at your mod's i doubt your dealer will touch it ....unless they are super cool or need the work.
Mods:
-Powder Coated Wheels (Steel Grey)
-TTR Rear Sway Bar
-ARK Shorty Antenna
-TWM STS
-Megan Racing Catback
-Hahn Catless Downpipe
-3rd Gen Projectors w/ 8000k HID's
-AEM CAI
-Hahn FMIC
-CIA Boost Tubing
-Trifecta Tune
-CF Trunk
Old Jun 29, 2009 | 04:41 PM
steddy2112's Avatar
Tune will kill it.
Old Jun 29, 2009 | 04:42 PM
Permafried-'s Avatar
Those codes are all severe misfires on every single cylinder...I'm not sure it would necessarily be just the octane level..I think you have bigger problems. Lifters, valves, springs, etc...something let go for the engine to misfire that badly including uncontrollable revs...dear god not another one down
Old Jun 29, 2009 | 04:54 PM
Bad05SS's Avatar
lol 3-2 isnt good i have done that lol who said you cant hit 7500 rpm lol
Old Jun 29, 2009 | 05:00 PM
HB_SS/TC's Avatar
My dads the mechanic at the dealership so they'll touch it. lol
He said he isn't worried about the mods just to put the stock ECM back in
Old Jun 29, 2009 | 05:09 PM
PSHHH's Avatar
lucky lucky lucky.....................
Old Jun 29, 2009 | 05:14 PM
TrevMo's Avatar
Reason #32,898 for the GM bankruptcy...
Sometimes I wish people were a bit more ethical in this world...
Old Jun 29, 2009 | 05:35 PM
HB_SS/TC's Avatar
I'm sorry you feel that way but 99.9% of dealership employees abuse the warranty system
Old Jun 29, 2009 | 05:45 PM
TrevMo's Avatar
That doesn't make it right...just ruins it for the rest of us...
Old Jun 29, 2009 | 06:15 PM
Donny Brasco 2's Avatar
7000rpm and race gas...LOL
Thats a serious combustion problem.
Old Jun 29, 2009 | 06:19 PM
ls1fbody's Avatar
Haz l33t wheelz.
David, where you running 109? i thought you had pump gas in...
the different octane won't make a difference in the injectors themselves. You weren't tuned to 109, so it really won't make the car different, except it won't pull timing as much because it would resist detonation better.
unless the car is that reactive, which i doubt, it would run off its previous curves and reactions for 91. maybe if you ran a tank or 2 or 109, it might start adapting to that level of octane. but i doubt it.
Old Jun 29, 2009 | 06:41 PM
blackbolt89's Avatar
misfire on every cylinder eh?
you must have done something real stupid for that one.
Old Jun 29, 2009 | 06:57 PM
hilty003's Avatar
i wanna hear what the dealer says broke.
