17 inch slick..will it rub?
Old Sep 24, 2009 | 11:49 AM
Projekt's Avatar
you guys think a 17 inch slick would fit even when lowered?? (obviously on a 17 inch rim not stock rim)
Old Sep 24, 2009 | 11:59 AM
Jackalope's Avatar
17 inch wide? I doubt it.
Projekt's Avatar
lawls.
Old Sep 24, 2009 | 12:02 PM
Jackalope's Avatar
Seriously tho you TC guys have clearence issuse due to the caliper don't you? Have you found 17 inch wheels that'll work? If so then yeah you can stick slicks on them and you should be just fine. Slicks come in all sizes just like regular tires, you'll be fine so long as you have wheels for em.
Old Sep 24, 2009 | 12:07 PM
Projekt's Avatar
durr thats what im saying jack
theres a 17 inch rim that clears..no spacers..however im lowered..you think a MT slick would still fit without rubbing?
Old Sep 24, 2009 | 12:09 PM
Jackalope's Avatar
What size tires are you running now?
Old Sep 24, 2009 | 12:10 PM
Projekt's Avatar
stock 225's on 18's
Old Sep 24, 2009 | 12:14 PM
Jackalope's Avatar
The only slicks I could find from M/T in 17's are these ......
http://www.mickeythompsontires.com/s...StreetRadialII
And then 1 from this series.....
http://www.mickeythompsontires.com/s...ETStreetRadial
Hope this helps.
Old Sep 24, 2009 | 12:16 PM
eaglegsw14's Avatar
what 17 inch rim will fit?
Old Sep 24, 2009 | 12:18 PM
Projekt's Avatar
msr 068
Old Sep 24, 2009 | 12:25 PM
eaglegsw14's Avatar
how much do those things weigh though?
Old Sep 24, 2009 | 12:28 PM
Jackalope's Avatar
Here's a site that does a comparison and gives the tire differences too.
http://www.1010tires.com/TireSizeCal...?action=submit
Old Sep 24, 2009 | 12:34 PM
eaglegsw14's Avatar
thanks
/end thread jack
Old Sep 24, 2009 | 12:37 PM
cmiller8006's Avatar
msr 068
Sent you a PM, but didnt answer the question. The slicks should fit fine.
Projekt's Avatar
okay im looking for some over winter so i dont have cash right now. thanks anyways tho
Old Sep 24, 2009 | 12:39 PM
Thats cool, just thought I would throw it out there
Old Sep 24, 2009 | 12:40 PM
Projekt's Avatar
thanks, apperciate it
Old Sep 24, 2009 | 12:49 PM
Sweetsandman's Avatar
I think drad radials will be the only things that'll fit on 17s...I think for true slicks you'll need to do a brake swap and get 16s then run motorcycle slicks.
Old Sep 24, 2009 | 01:34 PM
eaglegsw14's Avatar
whats the difference in DR and slicks?
Old Sep 24, 2009 | 01:35 PM
Jackalope's Avatar
DRs (Drag Radial) are street legal and have tread. Slicks are not.
Old Sep 24, 2009 | 03:13 PM
hallss's Avatar
and a drag radial is a radial tire which means they have stiffer sidewalls and a radial design. slicks usually ar bias ply and will wrinkle the sidewalls= better launch and 60 ft times. M & H has a 275-45-18 out def. wont clear your lowered car but their 275-50-17 might work
Old Sep 24, 2009 | 03:40 PM
glhs379's Avatar
I am looking at M/T et drag radials in i think 205-40-17
they will prob hook pretty well, as they are very very close to a slick.
looks like a slick with a few grooves in it to me!
Old Sep 24, 2009 | 03:43 PM
Way to small, your going to spin like crazy.
Old Sep 25, 2009 | 04:33 PM
mongorat427's Avatar
msr 068
That wheel is to narrow MT 17 need at the minimum 8 inch wheel. 9 inch would be better but I cant find any
Old Sep 26, 2009 | 02:15 AM
Gimpster's Avatar
My plan this winter (while doing the clutch) is to dump the Brembos and put whatever the smallest rotor/caliper combo I can on. I'll keep the Brembos in the attic in a box. I pretty much only drag race anyway.
Would really like to run a 15" wheel + slick. I just don't see the point in a 17" "slick" .... just cant get the sidewall I want on a 17 really.
Who woulda thought nice brakes would be our enemy.
