1st gear problem
Old Jul 1, 2009 | 04:41 PM
Shibito's Avatar
1st gear problem
Hey everyone, I was hoping some one would have some info to help me with my problem.
Every now and then when I try shifting into 1st gear from a dead stop it will not go in. After I shift into a couple other gears and try again it goes right in. This isn't a constant problem but it happens enough that it's getting very annoying, I'm going into a local dealership here in Florida (I'm on vacation) in the morning. Has any one else had similar problems?
All information is welcome!
Old Jul 1, 2009 | 04:49 PM
Terminator2's Avatar
Mine has done that a time or two sometimes the gears are between teeth and will not mesh properly the car has to move either foward or backward a hair to get it into gear.
Old Jul 1, 2009 | 04:54 PM
OneCOLDBIZL272's Avatar
common issue, mine only does it sometimes, your most likely going to have to deal with it.
Old Jul 1, 2009 | 04:56 PM
Shibito's Avatar
Ugh, really? Traffic down here doesn't like waiting
I hope not
This isn't a rare occurence at all, it happens about 50% of the time if not more.
Old Jul 1, 2009 | 05:02 PM
I hope not
If it is happening all the time it is likely either the shift cables needs to be adjusted or you have a bad 1st gear syncro.
Old Jul 1, 2009 | 05:05 PM
Shibito's Avatar
Alright, I have to be at the dealer at 8am tomorrow. Hopefully they can fix the problem. It didn't start until I was on my way down here and I couldn't get it into 1st at all, I actually had to let the clutch out a tad and slightly grinded it and then it went right into first.
Old Jul 1, 2009 | 05:07 PM
Probably your first gear syncro from what you just described. Hopefully they can duplicate the issue.
Old Jul 1, 2009 | 05:08 PM
Jalake's Avatar
I have the same issue, not very often. Im going to have them look at it when my car is in for the other issue.. the door rubs the fender when it is cold outside.
Old Jul 1, 2009 | 05:18 PM
RedBalt44's Avatar
this happens to me sometimes too. when im in a hurry to go i just throw it in 2nd and go. but other times i can throw it in 2nd and put it back in 1st and it slips right in.
Old Jul 1, 2009 | 05:37 PM
Shibito's Avatar
Alright, thanks for the input. I'll suggest the problem to them. I'm sure they won't have a problem duplicating it.
Old Jul 1, 2009 | 05:41 PM
tuner923's Avatar
grind em til you find em lol
Old Jul 1, 2009 | 06:13 PM
sbdblyss's Avatar
If you keep pressure on first gear and slowly let out the clutch, it should let it slip in.
Old Jul 1, 2009 | 06:16 PM
Shibito's Avatar
Tried that once but it wouldn't go in until it started to grind and I immidietely pushed the clutch back in and it went right into 1st.
Old Jul 1, 2009 | 06:21 PM
sbdblyss's Avatar
Thumbs down
Not good. It shouldn't take grinding to get it in. Take it to GM! It will probably take them a few days just to tell you that it's not going into first properly, lol.
Old Jul 1, 2009 | 06:32 PM
CobaltSS 16's Avatar
It could be normal as the others said. Just lift your foot off the clutch quickly (in neutral of course) and push it back down and try to go into 1st. It should slide in easily after that. A little blip of the throttle helps it slip in also.
Old Jul 1, 2009 | 07:46 PM
tomj77's Avatar
try this it worked for me in my sunfire, before u go into first shift into reverse and then it will line everything up for some reason and 1st will work. i have that sometimes in this car to but when i slowly let the clutch out it does pop in.
Old Jul 1, 2009 | 08:03 PM
sbdblyss's Avatar
Ya, same here. Reverse always works and so does messing with the clutch. It also happened in my Acura RSX all of the time.
Old Jul 1, 2009 | 09:32 PM
dnasty88's Avatar
says in the manual if it doesnt go in 1st or reverse either push the clutch in and out again or shift to another gear and back in to 1st or reverse
Old Jul 2, 2009 | 08:42 AM
CudaJoe's Avatar
This happens on all manual cars.... or at least all the ones i've been in. Chances are you wont find yourself between the teeth all the time. going from 2nd gear to 1st is a good solution for that but even better solution is to go from reverse to 1st.
Old Jul 2, 2009 | 08:44 AM
06G85's Avatar
My 2001 Cavy did that all the time. Never knew what the problem was.
Old Jul 2, 2009 | 09:30 AM
Permafried-'s Avatar
Correct.
Old Jul 2, 2009 | 11:15 AM
Shibito's Avatar
Update!
Originally Posted by Permafried-
Correct.
The first time it happened though I went through all the gears and reverse but it still wouldn't go into first. Let the clutch out and back in multiple times. It barely grinded for half a second and I had the clutch back in and it slid right into 1st no problem.
Update!
Went to the dealer this morning and they failed to duplicate the problem, I even drove around with the tech for half an hour and we couldn't get it to happen again so he told me to make sure I go through all the gears when slowing down and to bring it back if it started happening more often.
Old Jul 2, 2009 | 11:18 AM
CudaJoe's Avatar
fail. you worry wart, lol. we told ya!
Old Jul 2, 2009 | 11:24 AM
Shibito's Avatar
lol, yesterday this was happening every other time I came to a stop though, it hasn't happened at all yet today so maybe it was just a temporary problem?
Old Jul 2, 2009 | 11:27 AM
CudaJoe's Avatar
its sounds like you need to go to the casino since your lucky enough land between teeth at every stop!
