2009 LNF Wont go into Boost?
Old Apr 11, 2014 | 05:22 PM
SexySS's Avatar
Hey guys I need some help! My 09 LNF Will not go into boost... if im driving and I step on it my boost gauge will be at zero and it wont let me go past about 4k rpm's. My first thought was a boost leak of some kind but I checked the charge pipes and there are no cracks and ive checked the couplers and they are sealed and on tight.
Any ideas of what else it could be? any help is appreciated!
Thanks,
Old Apr 11, 2014 | 05:25 PM
user 72239's Avatar
Did you check your MAP sensor on lower CP and did you check your IC for leaks? Also, did you check your upper CP and make sure its still attached to the turbo? Any codes? when mine did this it my upper CP.
Old Apr 11, 2014 | 05:30 PM
SexySS's Avatar
The Sensor is connected to the lower CP and I thought it was the intercooler so I put a new Hahn IC on and it still did the same thing. And the upper CP is connected to the turbo. it did throw a code.. I erased it tho umm. I think it said something about the wastegate?
Old Apr 11, 2014 | 05:31 PM
brianhud1991's Avatar
Do you have a vacuum leak? You'll know if your boost gauge needle fluctuates when your driving slowly during vacuum
Maybe your BPV on the left hand side of the turbo is stuck, the spring? Maybe from grime and possible oil pass through intake.
Old Apr 11, 2014 | 05:34 PM
SexySS's Avatar
That might be it! ... how would I go about fixing that?
Old Apr 11, 2014 | 08:00 PM
dcrep06's Avatar
id be willing to bet its the shitty BPV if you have no boost leaks else where. the stock one is garbage and sometimes gets stuck open or closed, i had that happen before but mine went off and on, either 3psi from being stuck open, or 25psi (on a 20psi tune) when it got stock closed. just an idea.
Old Apr 11, 2014 | 08:51 PM
Right above where the intake goes onto the turbo there is a tan casing with three bolts, I believe 10mm. Unbolt them and hold on to it as the spring is compressed within.
From there make sure there's no crap in the spring to inhibit the functionality.
Also, you might want to take off your intake as that back bolt is a ***** to get to.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
