2011 buick LHU block handle ???
i've already seen 2012' GS LHU stock block dyno at 560hp w/e85/35psi - with cylinder #1 & #3 cracked from top to bottom.
the LHU & LDK blocks alone can handle up to 460-480'ish with a reliable tune..
Past 550+ the block needs to be girdled, these blocks in stock form weren't meant for high boost - over 30+psi, using a girdle system will prevent this from happening..
