Is 24 psi 24 psi?
Old Mar 20, 2014 | 09:55 PM
cfsnipers's Avatar
Is 24 psi 24 psi?
Hey all. Was just wondering if 24psi from my stock K04 is going to have the same power and torque as a ZFR at 24 psi. I know the ZFR is a bigger turbo and if I wanted a power increase in the future it could be on tap with a re-tune. But is it worth it with a 91 octane tune and trying to maintain engine life?
Old Mar 20, 2014 | 10:21 PM
thedubsack85's Avatar
Not even close to the same power levels. Your talking about the max safe zone for the K04 and a low psi tune for the ZFR... It's really only a measurement of restriction in that you could make the same/more power on 20 psi with the ZFR than you could at 24 on a K04... Get it?
Old Mar 20, 2014 | 10:22 PM
tomj77's Avatar
Zfr flows more air so no, zfr will make more power at 24 psi than k04
So k04 at 24 psi would flow 24 pounds per square inch of air at 32 lbs a minute and zfr would flow 24 psi at 54 lbs a minute. So both turbos compress the air the same, but zfr pushes that 24 psi into motor faster so u got more air in cylinder at 24 psi on zfr then u would on a k04 at the same psi
Old Mar 20, 2014 | 10:33 PM
tomj77's Avatar
If I have those numbers right that is
Old Mar 20, 2014 | 10:54 PM
SLRdohc's Avatar
just remember PSI means absolutely nothing!!
Old Mar 20, 2014 | 11:02 PM
tomj77's Avatar
See that's not true. Psi does mean something. If u had 54 lbs/ minute going into the motor at 1 psi ud make less power than at 24 psi. U compress the air charge more it holds more oxygen than when u compress it less. So obviously it means something. I think the better thing to say is psi or airflow by themselves mean nothing, u have to look at both really.
Old Mar 20, 2014 | 11:05 PM
cfsnipers's Avatar
Excellent. Thank you gentlemen. My K04 at 24 psi is very motor safe. Can the same be said of the ZFR?
Old Mar 20, 2014 | 11:13 PM
tomj77's Avatar
Zfr at 24 psi will be motor safe, but not trannysafe, due to it makes a lot more torque very quickly at low rpm, almost like pretty much as fast as with stock turbo , so all that power coming on with stock tranny and 3rd gear go boom. Gotta tune so torque doesn't come on so quick or even better, get a Powell 4.45 gear tranny upgrade like gonna have to lol
Old Mar 21, 2014 | 08:11 AM
cfsnipers's Avatar
If mine blows I'm getting a 6 speed. I have enough money in the car to justify it. Plus I'm keeping it for a long time so why not.
Old Mar 21, 2014 | 08:20 AM
CudaJoe's Avatar
zfr flows better so for ricer math purposes lets just say where a 24psi k04 makes ~315whp, and zfr at 24psi might make ~380whp.
Old Mar 21, 2014 | 04:32 PM
raver0789's Avatar
No the powers is different. Compressor maps and efficiency ranges for the two different turbos vary greatly, and so will performance.
Old Mar 21, 2014 | 04:38 PM
taintedred07's Avatar
Lol at op's question, but that's what is so great about the zfr. Even at the same psi levels you're going to have more power and a broader powerband till redline that won't die off around 5-6k like the k04.
Pretty much what everyone else said
Old Mar 21, 2014 | 04:47 PM
slapbetcommissioner's Avatar
I don't know if this is strictly true but I have noticed it in most cases.
Pressure seems to increase torque more then hp
And flow seems to increase hp more then torque
Old Mar 21, 2014 | 04:50 PM
Obviously there are many factors but Just to simplify it...
Old Mar 21, 2014 | 05:02 PM
sstcsfsd's Avatar
Would the increased efficiency of the zfr create less heat of the compressed air, compared to the heat created at the limits of the k04?
Old Mar 21, 2014 | 05:03 PM
AaronJ's Avatar
My head sort of hurts after reading those responses.
PSI is basically a measure of the head loss in your piping system. The head loss is a function of the density of the air and the restrictions in your system. Two turbos boosting 24 psi just means that the head loss between the two is the same. The flow rates are different because one turbo might be more effient than the other in that range, meaning the charged air is less hot (more dense).
Old Mar 22, 2014 | 08:23 PM
huckernage's Avatar
u are really close
I did 31 lbs/min and dyno 318whp. our hhr zfr did 39 lbs/min and 390 whp
Old Mar 23, 2014 | 02:08 PM
tomj77's Avatar
so I guess to summon up what everyone said, yes 24 psi is 24 psi, how much air the turbo flows is what makes the difference. end thread. lol
Old Mar 23, 2014 | 06:39 PM
UltraSilverSS's Avatar
Put both on high and check for results
Old Mar 23, 2014 | 06:57 PM
tomj77's Avatar
nice lol
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
