2nd guessing my new LNF
Old Sep 20, 2012 | 02:08 PM
Nfamous60's Avatar
all cars have their faults man dnt even see why that would bother you as much unless u r the type not to take care of your ****. brought my car with 22k did basic maintenance added more power and only thing i did was blow the turbo which opened up doors for a complete engine build and turbo swap....u have nothing to worry bout treat her right and she will do the same.......and my stock turbo blew at 31psi. if you were wondering.
Old Sep 20, 2012 | 02:10 PM
bradpittman's Avatar
Originally Posted by SSlobalt
You can probably snake a bore-scope in through the brake booster port.
You can absolutely do that very thing. This is literally a 2 minute procedure.
Don't worry about the build up. If the car is stock then the warranty will easily cover the repair. If you aren't stock then you should learn some wrenching skills anyway. Follow some of the rules for reducing the chances of buildup (at least according to the folks over at Powell).
Don't load the engine at low RPMs.
Do use a Euro spec low ash oil.
Do consider a mod to deal with the crankcase vent vapors
Do consider an alternative to the oiled K&N style filter.
Do stand on the long skinny pedal once or twice a day.
Old Sep 20, 2012 | 02:23 PM
umrdyldo's Avatar
Anyone have suggestion on a low price bore scope?
I'm not spending $300 on this.
Old Sep 20, 2012 | 02:43 PM
DirtyBalt09's Avatar
People that are seafoaming every oil change are changing plugs every oil change also?
Old Sep 20, 2012 | 02:50 PM
umrdyldo's Avatar
Nope not I. It's not required. I'm doing it soon though due to 50 miles on the clock.
Old Sep 20, 2012 | 03:06 PM
joepackersrock's Avatar
No you just have a set of "seafoam plugs" that you swap in, then when finished pop your good plugs back in and your all set.
Old Sep 20, 2012 | 04:21 PM
Check Amazon.com for usb scopes. They are cheap and work with your laptop. You can find a stand-alone version for a little over a hundred there as well.
Old Sep 20, 2012 | 04:23 PM
Chevy_tuner's Avatar
Seafoamed plugs? So one must not just use sea foam straight up?
Old Sep 20, 2012 | 04:53 PM
Sully20's Avatar
I got 42,000 and I'm running some nice mods and have not sea foamed once and I have no issues as well, I LOVE the LNF and I've owned both the LSJ and LNF and the LNF wins hands down. Keep it, Trust me
Old Sep 20, 2012 | 05:05 PM
BlackLsCoupe's Avatar
mines fone 83k mines and still getting 35.7mpg average. BG has an induction clean for DI works great my motor was just apart and they said everything was spotless.
Old Sep 20, 2012 | 05:36 PM
  #36
Sully20's Avatar
I believe you put it in with gas when you fill up
Old Sep 20, 2012 | 05:59 PM
  #37
Soofisahab's Avatar
No need for seafoam plugs. The seafoam doesn't effect the plugs and the carbon doesn't deposit when passed through cylinder.
Old Sep 20, 2012 | 07:07 PM
  #38
There are instructions on the bottle on how to use it. With an LNF I would suggest using most of it in the vaccum not the gas since its a directed injected motor.
I use it all the time on my 3 other cars. No problems ever. (knock on wood )
Old Sep 20, 2012 | 07:10 PM
  #39
Ch1ck3n's Avatar
47k on the clock, Only thing I've ever had wrong with the car was a popped intercooler and had to replace the o2 sensor i killed with ethanol. Couple of Seafoam jobs here and there.
Don't afraid of DI, there's a reason car manufacturers are switching to it. If you're that worried, just pull the intake manifold and clean the valves. It's not that big of a deal.
Old Sep 20, 2012 | 07:27 PM
  #40
^hey your car in the sig looks exactly like mine...LOL
Is it true I can not reuse the same IM gaskets?
Old Sep 20, 2012 | 07:32 PM
  #41
dcrep06's Avatar
75k and mine runs great, never used seafoam either.
  #42
Cobalt_Daddy's Avatar
you'll be fine lol you've got a few years where the power train will cover it. worse case scenario you can have it cleaned.
Old Sep 20, 2012 | 08:07 PM
  #43
rukkee's Avatar
I replaced my intake gasket ..... they are cheap ....like 10 bucks .
I've been seafoaming since new , i posted pic's at 47K (pics in my gallery) and they were a lot better than I expected them to be . Pulling the intake isn't much of a problem ..... shouldn't take more than an hour of so.
I used to replace my plugs at the same time but found that it didn't effect the plugs as far as i can tell ..... so now i change plugs every 10-15K miles.
Old Sep 20, 2012 | 08:17 PM
  #44
LOL Everyone is posting their little miles.....Im talking over 100k on the clock.
Old Sep 21, 2012 | 06:27 PM
  #45
rukkee's Avatar
How would we know that you were looking for 100K mile LNF's? I didn't see anything about 100K .....
you were asking about the intake gaskets ..... so i replied. Most people start taking care of the intake valve issue long before 100K .
Old Sep 21, 2012 | 06:38 PM
  #46
Sox-Fan's Avatar
Got Brakes?
Valves in this engine are no frickin worse than your mother's old Pontiac that had a 305 ci pushrod V8 with a smog pump and a carburetor. Just drive the frickin thing.
If you're that afraid of it use a low ash level oil, change it regularly, keep the boost to realistic numbers, and get a catch can.
Old Oct 1, 2012 | 02:40 AM
  #47
4g63killer's Avatar
Meth
Old Oct 1, 2012 | 07:44 PM
  #48
rukkee's Avatar
At least that old Pontiac had fuel flowing over the intake Valves to help keep deposits down. lol
There is no reason to worry about it much ........ Worse case is you have to pull the intake off and clean them by hand ..... 20 bucks in gaskets and your done.
Old Oct 1, 2012 | 08:36 PM
  #49
dcrep06's Avatar
i just swapped my intake mani and my valves looked pretty damn good might i say 76,xxx miles later
Old Oct 1, 2012 | 09:11 PM
  #50
Sox-Fan's Avatar
Got Brakes?
and leaky rings and leaky valve guides.
Point here is that when all is said and done there's a lot being said but really not a lot needing to be done.
