3 bar map sensor
3 bar map sensor
On cate engine depot there is a 3 bar map sensor. Will this work on our LNF's?
http://www.crateenginedepot.com/stor...P2533C196.aspx
Those will work on the lnf only if you flash a gmpp tune with hptuners, or you let vince@trifecta make you a tune for them, you also need to buy some o-rings and connectors for them and splice them into the stock wiring.
