3 bar map sensor GMS1 LNF
My car is currently stock, and I'll ?probably? keep it that way. Would there be a benefit in getting an HPT tune with the stock MAP sensors? Perhaps run about 5 psi more than stock (20ish) to keep things REALLY safe, but still gain a little hp? I bought the car for fun and longevity, lol (i.e., DD).
ehh without a log that's sort of a difficult thing to claim for sure, and even in a log you would have a really hard time judging a spike when running a 23psi tune because the stock sensor can not register much over 23psi (about 260kpa). So anything beyond 23psi would just be a flat line. Maybe you're absolutely right and it doesn't spike, but if you're going purely off of what the boost gauge or rpd is registering, it's not always accurate and is tough to judge particularly while driving. I'm not trying to convince you, or anyone for that matter, that you absolutely NEED th 3bar map sensors BUT it is really a good idea in most cases from a tuning stand point.
You can tune it to whatever your liking. If you want only 20psi, then by all means that can absolutely be accomplished with ease. The stock sensor in the lower charge pipe has enough head room in it (about 23psi) to dial in a 20psi tune pretty well all while being able to see any spikes, particularly at high load/low rpm conditions.
Appreciate the response, man! I'll be looking into this down the road.
the ecotec motors are great. i had 30k and 65+ dyno passes on mine old car(stock bottom and top end, stock trans with a spec stage 3+, and on 93 octane)with 2 different large turbo setups that both made over 400whp, long trips and daily driving. never spun a rod bearing, never blew up the motor internally, never blew up the trans or anything else. the car was still going strong before a semi truck hit me.
safe all depends on what you do, how you treat and how the cars setup and tuned. 3 bars for the money are 100% worth the extra cost. just like the phenolic spacers. they are cheap mods for the car. HPT you dont have to buy just find someone thats VERY REPUTABLE that can tune with it. the benefit from hpt is that if you have someone good they will spend the time to go over every single aspect of your tune and have somethihng right in front of them to look at.
yeah. 80mph impact leaving me standed 500 miles from home in the middle of no where and the jack ass took off.... such is life sometimes. took 2 years to perfect that car to be destroyed in a matter of 10 seconds. oh well what can you do?
Da zam! Thats Crazy....It seems like your lucky to be here too! Hey man at least your ok right? Dont get me wrong that sucks too tho!
FWIW i just have the GMS1 tune flashed in my car right now with stock map sensors and its a 20ish lb tune... if it spins you'll peg the sensors at 25.4lbs pretty easily if you have a downpipe and exhaust...
Holy $heet! Glad you made it out alive.
Also, would you have the enormous spike without the d/p/exhaust combination (plus spinning, lol)?
GMS1 on a stock car would equal XXX.XX whp?! I'm curious. How do you get just the tune? Just go to a GM stealership and ask for the tune?
The low res 2.5bar map in the lower charge pipe "pegs" at about 262kpa (23.5psi) and the one in the manifold caps out at 22.5 in a log. Anything you see on your boost gauge or rpd over 262kpa is just a guestimate by the ecm, so it may not be accurate. The 3bar maps cap out a little over 29psi so there are plenty of head room in those to easily and relatively accurately register a 25+psi spike. If you really want to accurately monitor your boost for spikes over 23psi from inside the car you may want to consider investing in a true aftermarket mechanical gauge.
Quote from Vince @ Trifecta:
"The stock boost/MAP sensors are 2.76bar, and the GMS1 sensors are 3.30bar. That means the lowest maximum boost level supported on the stock sensors is 1.76bar, or about 25.5psi at sea level and more at altitude.
Aftermarket tuners modify the diagnostic criteria to allow the sensor's entire range to be used to avoid this issue. Because of this, there is absolutely no performance or tuning benefit to installing the GMS1 sensors with the stock turbo. If you're going to run in excess of 25.5psi at sea level, with, say, an aftermarket turbo, that's a different story. Again, it's not a strict requirement though since boost level can also be controlled by the torque strategy".
Sorry but that's incorrect. Straight from Vince or not, it's just flat out incorrect. 262kpa (2.62bar) is all you can squeeze out of the low res sensor even with the max range setting maxed to 400kpa!
As far as custom tuning software goes, there are really only 2 options. Trifecta and HPTuners. Trifecta is tuned by literally one person (Vince) and ONLY Vince. The "dealers" quite literally only load the tune for you. HPTuners on the other hand is also full custom tuning software, but if tuned by a competant tuner, can make more hp in my personal opinion (although some may disagree). Either way you go, your custom tune will reflect your existing bolt-ons to maximize the cars potential and driveabilty.
Define "better", when every customer has different goals.
For instance, every person except 2 in the SE Texas area that I can think of has blown their engines at least once on HPT. It all depends on the tuner, customer's goals, particular car, and tuner's experience.
Yes $17 is correct for the map sensor (you will need 2) but you will also need either tha pigtails to splice in place of the 2.5 bar connectors, or purchace the plug and play connectors (best option in my oppinion). Here is a list of what you will need:
3 Bar MAP Sensor 55206797 (x2)
O-RING 3 Bar Map Sensor 12626998 (x2)
Cobalt, Solstice, HHR Stage Kit Harness Adapter 19212670H
As far as custom tuning software goes, there are really only 2 options. Trifecta and HPTuners. Trifecta is tuned by literally one person (Vince) and ONLY Vince. The "dealers" quite literally only load the tune for you. HPTuners on the other hand is also full custom tuning software, but if tuned by a competant tuner, can make more hp in my personal opinion (although some may disagree). Either way you go, your custom tune will reflect your existing bolt-ons to maximize the cars potential and driveabilty. Your best bet is to get all of your bolt-ons installed before you get tuned, but you WILL need to be tuned for the 3bar map sensors basically imediately if you plan on going into boost at all.
Will we need to buy that 11589015 M4 bolt that is included in the original kit?
No not yet, I've got a turbo xs catless dp and exhaust laying in my bedroom waiting to go on and pretty soon I'm going to buy an intake, intercooler and charge pipes. Assuming all that doesn't make me a throw a CEL I will then probably just wait until next summer to get the trifecta tune because cash will be a little more readily available then.
patooyee
Oct 1, 2015 01:07 PM
