3" down to 2.5"
Old Oct 28, 2010 | 01:01 PM
Cpanthers85's Avatar
3" down to 2.5"
This maybe a bit of a noob question... but I am going to ask anyway...
I am looking at doing a 2.5" Cat-back exhaust. I am pretty much sold on the fact that I don't need 3" all the way back because I'm not putting out enough HP and i could potentially loose bottem end HP. I want to change the DP too. I am looking at the catted Hahn, but my question is, will it matter if thats 3" and the exhaust is 2.5"? Should I stick with the stock DP? or should I try and find a 2.5" DP with a high flow cat?
I guess with my basic knowledge, if the DP is 3" and the exhaust is 2.5" it will create a bottleneck effect and will not flow well. Thanks for the input...
Old Oct 28, 2010 | 01:05 PM
Staged07SS's Avatar
Administrator
Administrator
This is not totally true. There are more important things in an exhaust system then just flow (like exhaust gas velocity).
Your car already comes with a pretty good 2.5" catback exhaust from the factory. The biggest bottle neck in the SS/TC's exhaust system is the downpipe. Replace that, and leave the stock catback. No need to replace it with an aftermarket 2.5" catback, unless you want a louder sounding exhaust.
Old Oct 28, 2010 | 01:09 PM
ecot3c inside's Avatar
I thought it was a 2.25"?
Old Oct 28, 2010 | 01:12 PM
Thanks..
on the TC its a 2/5". And yeah, I wanted something louder and more aggressive.
Old Oct 28, 2010 | 01:14 PM
oh, tc gotcha. me<reading.
Old Oct 28, 2010 | 01:19 PM
Staged07SS's Avatar
Administrator
Administrator
The SS/SC has a 2.5" catback as well, but it necks down to 2.25" over the rear axle to the muffler. The SS/TC's is 2.5" all the way back.
Old Oct 28, 2010 | 01:33 PM
slapbetcommissioner's Avatar
I doubt you would lose any bottom end horse power. The back pressure all comes from the turbo, anything behind that is just lost hp. Go 3 inch if your gonna waste your money (unless you go bigger turbo there is little to no gains from anything after the down pipe. Or an I infiniboost tune might put you almost to where you need bigger exhaust. Almost... If your looking for louder muffler resonator delete and a catless downpipe.
