3 questions for the tc
Old Apr 6, 2009 | 09:39 PM
jaygo7007's Avatar
1. plan on buying a downpipe in the morning at modernperformance. they have the hahn downpipe. i was wondering with downpipe should i get a hi flow cat or run no cat at all?
2 by adding the downpipe what would i see besides a little more power, would this make my exhaust louder? (because thats what im aiming for, i have a 3inch megan catback)
and lastly 3. how would you know if your clutch is slipping?
because i would redline 2nd and no lift shift to 3rd gear and everytime i do it doesnt wanna go into gear or it would grind really bad.
thanks
Old Apr 6, 2009 | 09:43 PM
CinciSS07's Avatar
is you car in competitive mode when you try to nls?
Old Apr 6, 2009 | 09:56 PM
RYRO14's Avatar
It doesnt matter if he is in Competitive Mode, the reason why your gears are grinding is because you are letting off the clutch to soon after you put in third. Yes I would go catless because you will see better numbers, and yes downpipes will add some noise
Old Apr 6, 2009 | 10:01 PM
jaygo7007's Avatar
1 time it was in comp mode the other time it wasnt.
i would be holding the clutch in and it still grinds but thanks.
i wanna go catless but worried bout not passing emissions test
how would i know if my clutch is slipping tho
Old Apr 6, 2009 | 10:13 PM
BartSS's Avatar
Go catless it will be louder and your turbo will spool faster. And SS for your clutch slippind. When you shift gears and your rpm goes up but you're not moving like you should be means that its slipping plus you would get like a skreeching noise when you shift. Hope this helps
Old Apr 6, 2009 | 10:24 PM
FutureEcotecOwner's Avatar
Go catless with cutout!!!
Old Apr 6, 2009 | 10:45 PM
jaygo7007's Avatar
kool thanks i plan on buying these in the morning
http://www.modernperformance.com/hah...bo-p-1901.html
and
http://www.modernperformance.com/vib...er-p-1254.html
Old Apr 6, 2009 | 10:52 PM
BIGTAG's Avatar
yeah go catless and when your clutch is slipping its almost like wheels spin you make alot of noise but dont go anywhere
Old Apr 6, 2009 | 10:59 PM
RYRO14's Avatar
Ohh im sorry you cant NLS, yes you are letting out the clutch to soon *******, its pretty much impossible to grind with the clutch engaged. That sucks about emissions, you can get catless and just put your stock downpipe on whenever you go for emissions
Old Apr 6, 2009 | 11:15 PM
jaygo7007's Avatar
who the **** you calling a ******* bitch. i kno what the **** im doing. u aint sitting next to me while its happening so just shut the **** up.
i asked a questions not to be called a ******* you fat ****
Old Apr 6, 2009 | 11:27 PM
Scott2008SS's Avatar
I probably would NOT recommend NLS with your mod's anyway. To prolong your clutches life. With a tune and your other mods, you could NLS but it will be tough on your clutch i would think. I think it was Dan from Clear Image said that he does not recommend NLS with a tune. But yea like everybody else said you will know when your clutch slips when you give it some gas your RPM's climb but you don't really move anywhere. If you are smart with it and don't floor it in 4-5th gear at like 2k RPM you should have better luck.
As far as you having issues grinding when doing the NLS i had that issue once when i first got my car and i was trying to hard (if that makes sence) I know i was, but who knows why your having that issue. Either way good luck!
Old Apr 7, 2009 | 12:37 AM
celicacavy's Avatar
you could have a clutch master cylinder or slave cylinder problem, that would cause the clutch to drag and not disengage fully and it would make it grind while shifting
Old Apr 7, 2009 | 12:04 PM
BartSS's Avatar
I had a bad throw out bearing when i got the car
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
