50 trim
Many upgrade to Bullseye 252, 256, 259, etc which are .49-.53. Others use bigger EFR turbos but I couldn't tell you more than that. Not familiar with them.
Idk, seems like the S252-256ET are pretty good as far as drivability. I didn't really spool up the S256 until 3100rpm but I still seemed to have decent power below that. You just couldn't really race anyone below that rpm which you wouldn't want to anyways.
S256 spooling at 3100 and making the power it does is a damn solid turbo, and which is why i plan on picking one up as soon as my car returns from the damage caused by a errant wheel/tire in the road.
if anything i may have an exhaust leak somewhere, but i dont hear any noises and my afr's are fine. usually a pre turbo exhaust leak makes your afr's all crazy.
so im thinking i just need a retune, otherwise i have no idea why it spools slow. i still get power tho.
im only running like 25psi on a conservative tune right now. tunes all fubarred too, since i found and fixed some boost leaks.
im probably as fast as a full bolt on ss/tc on e85 for now till i get a retune. i plan on cruising around on 25 psi and ill crank it up to 28 for kill.
Delta coupe
Sep 30, 2015 08:11 AM
