7163 Power???
Old Oct 2, 2020 | 04:18 PM
Raven2k's Avatar
7163 Power???
I’m thinking of running a
7163 ZFR
Stage 2 Cams
82 Springs and Retainers
Methanol Inj kit.
On Husky 94 Octane
Can someone give me an estimate of how much power I could make?
considering all other goodies and bolt ons are included.
I don’t have E readily available to me.
Old Oct 3, 2020 | 07:47 AM
63 Nova SS's Avatar
Depends on the tuner but somewhere in the 440whp-500 range.
Old Oct 3, 2020 | 01:33 PM
Raven2k's Avatar
Thanks! That’s good cause that’s around the power I’m looking for. Ideally I want 470whp.
Old Oct 3, 2020 | 01:40 PM
KMO43's Avatar
Where in Alberta are you?
Old Oct 3, 2020 | 01:46 PM
Raven2k's Avatar
Edmonton. Why do you ask?
Old Oct 3, 2020 | 06:26 PM
Raven2k's Avatar
also you’re the reason I decided to go 7163 over the 6758. I was really leaning towards the 6758 cause of faster spool but the 7163 has way more potential and benefits over the 6758
Old Oct 4, 2020 | 01:37 PM
KMO43's Avatar
I'm in calgary and have a 71 myself
Old Oct 4, 2020 | 04:20 PM
Raven2k's Avatar
yeah I was wondering how much do you think I could get out of that set up considering you have a good understanding of 7163.
Old Dec 4, 2020 | 12:03 PM
AG305's Avatar
with the 7163 i made 460whp on E at a conservative 24-25psi with a 100% stock engine
Old Dec 4, 2020 | 02:58 PM
T-Man's Avatar
I made a little over 460whp on E40, 18 degrees of timing and 26psi - 100% stock engine, clutch and transmission.
Old Aug 16, 2021 | 09:05 PM
DStidham71's Avatar
7163 ZFR
Stage 2 Cams
Methanol Inj kit.
On Husky 94 Octane
not sure if you have moved forward on youre build, but I have an hhr ss with the lnf. I have a zfr7163, 4" intake, 2.5" charge pipes, and a 3" catless down pipe. Tuned by Matt at zzp with hp tuners. I run 93 gas, and around 25 psi. Haven't been on a dyno, but move 50.1 lb/ft of air. So that means about 500 ish at the crank if my calculations are correct. I got 10psi up to 3000 rpm. 20psi by 3500, and 25-26 by about 3800-4000. Stock clutch held till the transmission started pouring fluid. Seems the higher rpm it goes the harder it pulls. The 7163 is great. I'm open to questions if you have any. I done it all myself but the tuning.
Waka Flocka Fluff
Sep 1, 2017 03:39 PM
Yaketysax
Jan 19, 2014 11:08 PM
Waka Flocka Fluff
Oct 29, 2013 07:50 PM
Ronn2005
Drag Racing
51
Jul 17, 2013 05:39 PM
lazaro
68
Dec 28, 2012 10:28 AM
