Where to go next?
Old Jan 17, 2014 | 09:04 PM
Yaketysax's Avatar
Where to go next?
*To start off, these are the modifications I've done:
K&N Typhoon SRI
Hahn charge piping (upper and lower)
Hahn Intercooler
Hahn Catless DP
Hahn Catback exhaust
ZZP 14.5" Front Brake upgrade
*My current goal is around 375-400whp (maybe more later?), running 93 octane (for now)
*Now, For what I need help on:
1) Am I ready for a turbo? (I know the clutch might need a replacement soon after)
-> Looking at the 256/259 extended tip or the ZFR
->[Edit]From what I gather the 259 will make more power, but slower spool. 256 will be slower spool but comparable power as ZFR. If I get the 256/259, do i want a .55 AR or .7 AR for my current goal? [/edit] (Thanks 09CobaltSS1)
-> As soon as I drop in the turbo, I'll be getting the car tuned for everything, is there anything else I need to drop it in? A wastegate?
2) From what I can tell, around this time [Valve Springs/Injectors/Larger fuel pump/cam with larger lobe] might be necessary. If it might help me from blowing an engine for some springs, then i'd definitely do that. If you recommend modifying one/some please include a size etc.
3) Is there anything I'm missing that needs replacing or might help? Once i finish on the engine, I'll be moving to lowering it, getting a beefier rear sway bar and getting rid of some nicks/door dings and making it look perfect.
I apologize if some of these/all of these questions have been asked before and noobish, but none of these questions are without prior research. I just want to make sure I'm not missing anything and get some more knowledgeable opinons. Thanks for any and all help!
Old Jan 17, 2014 | 09:25 PM
09CobaltSS1's Avatar
You have it a bit backwards my friend. The ZFR will spool quicker that the 256 or 259 and will also make less peak power, especially when compared to the 259.
Old Jan 18, 2014 | 10:05 AM
Shortbus's Avatar
If your goals are 375-400whp go with the zfr. It is completely bolt on, nothing else required. In the future it would be wise to look into getting a clutch and trans as the stock one tends to not be able to handle the tq of a zfr. If you plan on ever wanting more power you could run e85 with a 5th injector set up and the cam with larger fuel lobe.
Old Jan 19, 2014 | 11:08 PM
Yaketysax's Avatar
Thanks!
