Old Nov 22, 2009 | 06:48 PM
LE5_AJ's Avatar
How would i go about taking these wires out without breaking it??
Old Nov 22, 2009 | 06:55 PM
Iam Broke's Avatar
Most of those type of connectors have a barb on the pins that lock the pins in place once inserted into the connector shell. You need a split sleeve tool designed to remove the pins by compressing the barb.
Old Nov 22, 2009 | 06:57 PM
chevysssc's Avatar
you can buy weather pack plugs like that at the dealer if it breaks, good luck
Old Nov 22, 2009 | 06:59 PM
LE5_AJ's Avatar
**** this is stupid it's a brand new pump and i keep getting the same cel's but everytime i push the wire's into the connector the pump works but i have to hold it in so i was gonna rewire it. but by the sounds of it i can't
but do you guys have any tips for me i've been fighting this car for the last month
Old Nov 22, 2009 | 07:35 PM
Iam Broke's Avatar
If you can get to the edge of the female sleeves that the pins insert into, you could compress them a bit with a dental pick. They are probably a bit sloppy of a fit.
Tinning the pins with solder may help also, but it's a delicate process.
Old Nov 22, 2009 | 08:54 PM
LE5_AJ's Avatar
yea i couldn't get it i don't have the proper tools for the job... but i'm assuming it's broken because when you flick it or shake it it rattles inside and when you move the wires around when it's plugged in it'll make the pump run and when you stop it quits so this means it's broken correct??
Old Nov 22, 2009 | 09:09 PM
tomj77's Avatar
use a very small flat screwdriver to move the barb so u can pull it out, iv done it, but be careful
Old Nov 22, 2009 | 09:57 PM
Iam Broke's Avatar
It could be a broken wire but it just sounds like the pins are too loose in the connector to seat right or need to be spread a bit. I've gotten them out with a micro screwdriver before also, but there is a tool for it.
Old Nov 23, 2009 | 03:49 AM
SSlobalt's Avatar
Sounds like a broken pin to me.
Old Nov 23, 2009 | 12:09 PM
LE5_AJ's Avatar
Yea what are the chances i won't have to order one and i can get one in town??
Also what would this connector be called??
Old Nov 25, 2009 | 12:22 AM
LE5_AJ's Avatar
Bump!!! i need help would a solderless female connector would one similar to this work for my fuel pump male connectors i can't get it to the dealership if it keeps dieing from fuel starvation and the guy isn't helping at all
http://www.grainger.com/Grainger/ite...BaseItem=1DMA3
http://www.grainger.com/Grainger/items/1LEY3?Pid=search
