about charge pipe
Old May 28, 2014 | 06:40 AM
cobaltsstc84's Avatar
about charge pipe
I want to put a charge pipe on my cobalt lnf with stock turbo with injen intake and downpipe with gmpp1 tune... i have many 3inch tube... what you think about do it in 3inch... all aftermarket have 2.5 tube... i dont want to do it and have a negative gain....
Old May 28, 2014 | 07:42 AM
armcclure's Avatar
Look at the outlet of the turbo. Excessively large charge piping just dumps air velocity.
Old May 28, 2014 | 07:52 AM
The turbo outlet is 2 inch... you think its too big...
Old May 28, 2014 | 08:22 AM
blueLNFftw's Avatar
Just do 4" tube.
Bigger is better brah.
Old May 28, 2014 | 08:30 AM
Lol
Old May 28, 2014 | 08:31 AM
blueLNFftw's Avatar
More space means more flow.
Old May 28, 2014 | 08:43 AM
Just do 4" tube.
I bet you can squeeze a 5" tube no problem.
But seriously op 2.5inch is plenty for the ko4.
Old May 28, 2014 | 09:57 AM
Ok... i cant have one here for do myself but i will buy the injen i think...
Old May 28, 2014 | 10:00 AM
blueLNFftw's Avatar
Zzp
Old May 28, 2014 | 10:20 AM
TurboTechRacing's Avatar
We have the Injen in stock.
Old May 28, 2014 | 10:21 AM
Originally Posted by blackssstg2
zzp
x2
Old May 28, 2014 | 10:31 AM
What is your price for injen.... and why zzp is better ??
Old May 28, 2014 | 11:03 AM
www.TurboTechRacing.com we have all our products.
Old May 28, 2014 | 12:46 PM
footballplaya3k's Avatar
I think the Injen looks better. No functionality difference between ZZP and Injen except ZZP's has longer routing.
Old May 28, 2014 | 01:51 PM
JetLAGG's Avatar
ZZP for better fitment. No complaints and no more boost leaks or the charge pipe popping off.
Old May 28, 2014 | 02:07 PM
Shanedude's Avatar
OP I have stock charge pipes on for 160k. Never once had a boost leak or one pop off. Not sure how so many other's are having problems. They are very expensive for how little gains if any they make on stock turbo. I just see it as a reliability mod for a bigger turbo setup.
Old May 30, 2014 | 12:15 AM
Are you tuned? You've put 160k miles on your LNF? You sound cheap. Not everything is about gains...we upgrade the upper charge pipe for reliability and because we don't like shitty plastic in our engine bays.
Old May 30, 2014 | 02:25 AM
I have none of those problems, and if you get longer couples with the Injen like ZZP's have that point is moot.
Injen looks better.
are you tuned? You've put 160k miles on your lnf? You sound cheap. Not everything is about gains...we upgrade the upper charge pipe for reliability and because we don't like shitty plastic in our engine bays.
x2
Last edited by footballplaya3k; May 30, 2014 at 02:25 AM. Reason: Automerged Doublepost
Old May 30, 2014 | 11:07 AM
Shanedude's Avatar
Yes tuned GMS1 from 12k-130k and Trifecta from 130k-160k. It's Kilometers I'm from Canada if you could look to the left please it says I'm from Ontario.
If you want I can PM you when I do put on 160k miles on the upper charge pipe. I don't read of them cracking as often as people advocating to replace it asap. I am driving through hot summers and cold winters, not 1-2 season beauties. You naturally hear more bad than the good on forums.
Old May 30, 2014 | 11:22 AM
Always list units, ask Lockheed Martin and NASA about not listing units of measure. And just a fyi a lot of ppl view this site from their mobile(like me) and we don't see your location.
Old May 30, 2014 | 11:42 AM
Shanedude's Avatar
Okay will do. I haven't posted from mobile before.
To OP I'd be more worried about plastic end tanks on intercooler than charge piping. They are prone to being hit by accident. But if you have enough $$ buy the whole kit at once and be set.
Old May 30, 2014 | 11:53 AM
Joe09SS's Avatar
You'd think a pipe meant for boost would be round, not flat over the. More air flow through a round pipe than a flat one lol
Old Jun 3, 2014 | 03:40 PM
I'm not saying yours will crack, but I'm guessing you don't go to any meets, shows, etc and just use the car as a daily so you don't care how your bay looks.
Yeah, the thing looks like a pancake lol
Old Jun 3, 2014 | 03:45 PM
Have you studied fluid dynamics? Flat can flow just as much as round, not to mention with boost any little differences between a round or flat is out the window since your way into turbulent flow.
Old Jun 3, 2014 | 03:52 PM
Wired's Avatar
This. And the way it is routed makes it so you can actually work on your engine without pulling it off for any little thing.
