AC delete belt
Old Sep 20, 2013 | 03:34 PM
hucks1987's Avatar
AC delete belt
Does anyone what what part number or size belt is needed for a A/C delete?? Also is the ATI balancer the same side?
Old Oct 16, 2013 | 12:54 PM
FasterIsBetter's Avatar
Idk if you can do an A/C delete without an idler pulley to take place of the compressor because the tensioner would cause the belt to come into contact with itself due to the compressor not being there. But the size for the underdrive ati turbo balancer is I believe 15mm smaller than factory. Or at least that's what I think mine was. It fit tight but after a couple times of putting it on and taking it off it got easier as the belt stretched.
Old Oct 16, 2013 | 03:06 PM
northvibe's Avatar
I'd also be interested in this for future modding. I would suspect you could remove the AC compressor and put a blank holder w/ pulley. I haven't seen the belt diagram so idk if just removing that pulley part would make it rub.
How did the LSJ do it? I know they had the tune disable it, but did they do a new belt to "delete" it?
Old Oct 16, 2013 | 03:36 PM
jrmotosports 88's Avatar
from what i have read so far we gut the compressor. i have been reading into this topic for a few weeks now. i am going to assume the lnf's are the same. my biggest question is do we need to disable the ac compressor clutch sensor in the tune? or will it be fine? very few threads about this topic, very few people have done this. i believe mark(exsoccer/DS) may know a bit in this topic.
Old Oct 16, 2013 | 03:53 PM
AaronJ's Avatar
Unless you actually plan on removing the whole a/c system (compressor, condensor, evaporator, all the lines), I don't see what the benefit of this is.
Old Oct 16, 2013 | 03:58 PM
in my case thats the plan, im never selling the car, i dont use ac, ac condenser must go and yes the extra weight loss wont hurt.
Old Oct 16, 2013 | 05:47 PM
the ati balancer/super damper is on the same side
Old Oct 16, 2013 | 05:53 PM
EXsoccer1921's Avatar
You mean like this?
Old Oct 16, 2013 | 05:56 PM
thats pretty barebones huh! whats that a 1'-6" belt?
Old Oct 16, 2013 | 06:00 PM
well you did go to the extreme. hahahahahahaha
is the easiest way to remove the ac out of a lsj/lnf, what is the best way mark? to gut the compressor? and do you need to revise the tune?
Old Oct 16, 2013 | 06:08 PM
I mean I guess you could gut the compressor. But that pulley is still pretty resistant to spinning.
Old Oct 16, 2013 | 06:37 PM
cmiller8006's Avatar
I also deleted the compressor, go to autozone, look up a non ac 07 cobalt or so and get it. That's how I did it.
Old Oct 16, 2013 | 06:40 PM
They sold cobalts with no ac?
Old Oct 16, 2013 | 07:13 PM
Yea
Old Oct 16, 2013 | 07:19 PM
Grave's Avatar
4050345
That's what I'm using. (from Rockauto)
Old Oct 16, 2013 | 08:01 PM
i assume that would be the best solution for a lnf
need more belt with a sc.
Old Oct 16, 2013 | 08:12 PM
True
Old Oct 16, 2013 | 08:24 PM
For me deleting the ac was just a byproduct of going with the ewp. I did much more than just get a shorter belt. But if you just want the ac gone then yes that would work.
Old Oct 19, 2013 | 02:59 AM
GTOworshiper9's Avatar
Ecotec Belt w/o AC 24466976 12634322
Done.
Old Oct 19, 2013 | 03:29 PM
iboost's Avatar
Subd
Old Aug 19, 2017 | 04:07 PM
nutty21's Avatar
Sub'd
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
