AEM Dryflow filter VS K&N filter
Old Apr 19, 2011 | 12:55 PM
Ronn2005's Avatar
I have a HAHN Cold Air intake for my Cobalt ss/tc (work grate!).
The only thing that has bothered me is the K&N filter. I have never had a problem, but in the back of my head I always wonder if the oiled filter could skew the MAF reading a little.
Have anyone tried the AEM dryflow filter? (not the AEM Cold Air Intake I had it it sucks)
If you have used the AEM dryflow filter, does it give more accurate MAF readings than K&N?
Is it more idiot proof than oiling a K&N?
Old Apr 19, 2011 | 01:13 PM
Iam Broke's Avatar
It's idiot proof, but doesn't flow as well.
A properly oiled K&N flows well & from my 50k mile (5k on the oil) used oil analysis filters very well also.
If you over oil it, the maf readings will be affected until you clean the oil mist off of the MAF sensor.
Old Apr 20, 2011 | 12:34 AM
Ronn2005's Avatar
dude that's awesome. I never knew I could clean the MAF. I thought I couldn't touch the maf, and if I did I would damage it. So, do I just wipe off the maf with a rag, or do I use soap and water?
Old Apr 20, 2011 | 12:36 AM
DavidW's Avatar
lol youre kidding right
Old Apr 20, 2011 | 12:42 AM
ronn's Avatar
Originally Posted by Ronn2005
dude that's awesome. I never thought I could clean the MAF. I thought I could not touch the maf, and if I did I would damage it. So, do I just wipe off the maf with a rag, or do I use soap and water?
Soap and Water?
Take it from another *RONN* ( Yep I'm RONN..really..check it out)..use MAF cleaner:
CRC Industries 05110 Mass Air Flow Sensor Cleaner
Old Apr 20, 2011 | 02:42 AM
Macgyver2484's Avatar
And it comes with a PROVEN 4-10 horsepower increase to the wheels by just spraying it on. Forget the downpipe….all you need is this spray.
Old Apr 20, 2011 | 02:49 AM
ronn's Avatar
WTF does this have to do with HP and DP???
We're taking about CLEANING THE MAF here and>>>>drum roll>>>
NOT USING SOAP AND WATER TO CLEAN IT
..nothing more.
Old Apr 20, 2011 | 02:50 AM
AndrewSS/TC's Avatar
^your joking right...
Edit that was supposed to be below the guy saying it adds HP
Old Apr 20, 2011 | 09:16 PM
..nothing more.
It says right on the can that it adds 4 to 10 HP to the wheels! Everyone is adding downpipes for 10 HP when all they need is this spray.
Old Apr 20, 2011 | 10:04 PM
ronn's Avatar
Ok...you have a point there.
Old Apr 22, 2011 | 12:19 PM
Ronn2005's Avatar
Hey thanks for the info guys. I am going to clean my MAF today. OHHHH FYI dont try to cut the threads on t-bolt clamps, they will blow off when you get over 5psi boost. Haha yeah I learn things the hard way.
Old Apr 22, 2011 | 09:25 PM
gone_in_10_sec's Avatar
An cool trick I learnt from old school racers - "Dry bucket" was to take an old 2.5-3 gal bucket with the lid, paint it all black - lid and bucket, drill a few holes [5-10] on the side, insert a few rods/sticks in the hole you made to make a platform, now if you have something that is wet/ over-oiled and its hot & sunny outside, put the item inside the bucket and the heat will bake off the item until it's dry.. i've use my 5 gal bucket to bake off excess oil from air filters, oil tray, wet shop rags, etc..
FYI: to gauge how much oil is on the K&N filter, the filter element should look pink - not dark red or red, Dark red - too much oil, Red - oil needs to be dry, Light red - not enough oil, Pink - perfect.
Old Dec 24, 2011 | 02:39 PM
mmyers_417's Avatar
It adds hp bc when the maf is very dirty because of the dirt it sees less air volume so there is a possibility to gain hp but only on a high mileage cars with junk air filters
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
