Aeroforce Interceptor
Old Jan 10, 2009 | 05:18 AM
whitebalt's Avatar
would this work with the ss/tc (lnf) cobalts......
http://www.ottperformance.com/Cobalt...duct_info.html
Old Jan 10, 2009 | 11:19 AM
rat's Avatar
rat
It has been done before, someone posted pictures.
Old Jan 10, 2009 | 11:40 AM
redcomet303's Avatar
I wonder why It can't show the wideband sensor or does the lsj not have one?
Old Jan 10, 2009 | 12:07 PM
peachpuff's Avatar
Only the lnf has a wideband.
Old Jan 10, 2009 | 01:28 PM
IsItFast?'s Avatar
Did you even try to search? There are at least 3 posts in the last couple of months that I remember off the top of my head with this EXACT same question.
A few months ago, I posted in the general forum about the gauges I installed in mine - it even goes into detail about which features work and which dont!
Old Jan 10, 2009 | 05:41 PM
Then I will wait to get one of these till they make one that can read our factory wideband sensor then.
Old Jan 10, 2009 | 05:56 PM
08BlackSS/TC's Avatar
It can read the factory wideband right now.
Old Jan 11, 2009 | 12:09 PM
I see this thread was confusing not sure who was talking to who.
Old Jan 11, 2009 | 09:25 PM
IsItFast?'s Avatar
What works with the Aeroforce? (this is a list of things I have actually tested, its fairly comprehensive).
IAT1
IAT2
Ambient
Coolant
Catalytic Converter Temp
RPM
Boost
MAP KPA
MAF lb/m
MPH
Throttle Percent
Ignition Advance
Short Trm B1
Long Trm B1
Engine Load
Rail Pressure (BTW its around 550psi at idle FYI)
HP
Run Time
Barometric Pressure
Battery Voltage
Lambda
A/F ratio (YES it is a wideband)
MAF Frequency 1
Fuel
O2 B1S2
Oil Temp
instant MPG\MPG average
Misfires
Resetting the long term fuel works from the menu.
Resetting and reading CEL works
Fan controls (high and low) works
performance gauge works (measures 0-60, 1/8th mile, 1/4 mile times and MPHs)
Probably work but don't know how to test:
o2 current
ABS Throttle Pos
Knock 1
Does not work:
Fuel trim cell
A/F cmd
OIL PRESSURE (Damnit GM (and others), why cant you spend the extra few dollars on a simple sensor?)
Trans temp and basically all the sensors related to an automatic transmission (obviously). I dont have an automatic to test those, so someone with an automatic will have to test them.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
