aftermarket turbo setup question
Old Sep 2, 2011 | 06:16 PM
paintballerr78's Avatar
i have a pwerks 5557 turbo kit with manual boost controller. My question is can i just control boost without a manual boost controller and use HPT....a friend has basically same kit no boost controller and somehow is controller boost without a controller
Old Sep 2, 2011 | 06:28 PM
MastaShaKe_88's Avatar
i wanna know 2
Old Sep 2, 2011 | 06:38 PM
Chevycobaltss3's Avatar
u have the boost solnoids that control boost on the k04 u can use these but the turboneeds the same lbs spring for the wastegate. so if a turbo has a 8lbs spring in it then ure turbo needs a 8 lbs spring. i hope thats understandable
Old Sep 2, 2011 | 09:03 PM
slowbalt84's Avatar
I didn't understand what that guy just said but yes u can. That is how I control my boost on my 50 trim
Old Sep 2, 2011 | 09:11 PM
slowbalt84's Avatar
now read this very closely, this is how you use the factory boost solenoid. Mounted on the stock turbo there is a sensor with three vacuum lines on it. Once you get the turbo off you can remove the sensor and the lines. The bottom port (all by itself next to the electrical connector) will need connected to the hot side pressure pipe. The port on the side of the sensor will go to the diaphragm side of your wastegate. The top port leave open.
Old Sep 2, 2011 | 10:04 PM
what about the vacuum line on the turbo...and only how do i connect one to the hotside?
Old Sep 2, 2011 | 10:06 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the vacuum port on the turbo would be considered the hot side
Old Sep 2, 2011 | 10:13 PM
slowbalt84's Avatar
^yep
Old Sep 2, 2011 | 10:15 PM
oh well **** me then...your so smart josh
Old Sep 2, 2011 | 10:25 PM
dayhoff35's Avatar
good info subd incase i ever need it lol
Old Sep 3, 2011 | 09:34 AM
FrossB's Avatar
Thread Killer
HEEEEYYYYYYY. this was for me *blushing*
good info here! gonna check my lines later and see if i got everything hooked up right because i cannot boost over 20 pounds...unless i swap two lines around then i boost over 30...YIKES!
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
