Alignment after wheel bearing replacement??
Old Dec 21, 2009 | 01:20 PM
cresintern's Avatar
should i have recieved an alignment after my front wheel bearing replacement ? seems off to me. some say yes, others no
Old Dec 21, 2009 | 01:25 PM
mkriebs's Avatar
Yes. If you saw how all of it came apart to replace the bearing, you would see why, lol.
DEFINITELY recommended.
Old Dec 21, 2009 | 05:35 PM
DGAF260's Avatar
when changing any front parts it is a good idea to do an alignment. But a wheel bearing does not directly effect the alignment and you don't HAVE too, it is a good idea though.
Old Dec 21, 2009 | 05:58 PM
sstaton1983's Avatar
the only thing in the way is the axle nut. besides that the three bearing bolts. no allignment needed. but it never hurts
Old Dec 22, 2009 | 01:54 AM
Zander916's Avatar
Yeah it doesn't cause alignment to be off itself.
But if an alignment was done while it was worn it could be off a touch now that it's tight.
Old Dec 22, 2009 | 01:59 AM
mkriebs's Avatar
Well, whenever you take a bolt out, or loosen a bolt on the front end, it throws the alignment off. Think about it. You spec up the alignment with all the bolts in one place. Sure, there shouldn't be slack in the holes, but there is. Its not 100% perfectly tight fitting. Its definitely recommended.
Old Dec 22, 2009 | 05:32 PM
DGAF260's Avatar
you will never get alignments 100% damn close but there isn't a laser scope you can mount on the steering wheel to get it at perfect center.
Solaris99
28
Mar 15, 2017 01:22 PM
bigdeertz
Nov 17, 2016 09:41 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
