Another p2178
Old May 21, 2013 | 09:35 AM
jaygo7007's Avatar
Another p2178
Ok guys I'm back for help. I popped another cel p2178. And gets irritating me. It gave me 3 choices
1. Leaking injectors
2. Failed maf
3. I believe running rich. I forgot the 3rd choice.
Any idea where to start looking? I replaced the whole fuel rail with the 2010 upgrade fuel so I doubt it's the injectors. How would I know if my maf is bad? I know I need a retune so if any body can tune me please ley me know ASAP. I'm located in Houston Thanks.
Old May 21, 2013 | 09:44 AM
turbosmart4's Avatar
7135603889 his name is taylor and has lots of experience . Lives in houston too. Good guy. Someone might messege u giving u a bad review about him but its not his fault that person didn't take care of the car...... The guy is a GREAT tuner.
Old May 21, 2013 | 09:46 AM
He also swapped a LNF engine into his 06 cobalt successfuly, so he knows what he is doing.
Old May 21, 2013 | 10:09 AM
cubaniche's Avatar
Jaygo whats up dude!
P2178 is System Too Rich Off idle
Most ppl with this issue have found that they bypass valve in the turbo had a tear in the diaphragm. So a new bypass valve solved the issue. Others have replaced their MAP sensor and others have replaced the purge valve in the canister in the back of the car near the fuel tank. If this sticks open it could be constantly venting fumes into the IM.
If it were me, I'd check for small boost leaks and most definitely check the bypass valve in the turbo for tears. Is your turbo stock still? no blow off valve? Also if you have an untuned intake, it could also cause the code to pop up.
It all depends bro...
Old May 21, 2013 | 11:26 AM
jaygo7007's Avatar
Thanks turbosmart4!
Old May 21, 2013 | 11:33 AM
jaygo7007's Avatar
Thanks for the help Cuban. I'm on stock turbo with no blow off value. I have the Forge bpv. I Replaced the purge value in the canister about 7 months ago. Ill check for leaks today when I get off. Well make sure everything is tight since I don't have a boast leak tester
Old May 21, 2013 | 11:35 AM
Maccoy316's Avatar
I get this code and clean my MAF sensors and it runs like new. I'm sure I could replace the purge valve and it wouldn't keep coming back.
Old May 21, 2013 | 11:46 AM
jaygo7007's Avatar
Are you in Houston. I'm on my cell and it doesn't say where you are located. How much is a new maf? Or should I try cleaning it first
Old May 21, 2013 | 12:11 PM
Maccoy316's Avatar
I'm in Idaho. Not sure how much they cost but cleaning it takes less than 10 minutes.
Old May 21, 2013 | 12:48 PM
jaygo7007's Avatar
Ok when I get off and the temp cools down I'll take it apart and clean it
AfterShok
34
Jun 29, 2017 10:40 PM
tchandy
Jan 5, 2017 05:21 PM
Dustin24
47
Feb 12, 2016 04:10 PM
mirzabaig
May 2, 2015 12:08 AM
Stephenishere
Jan 19, 2013 09:22 AM
